Old 01-27-2008, 08:02 PM   #1
itzmarko1 is on a distinguished road
Question Left Turn Signal/Brake Light issue..
Hey everyone..
I have a 2000 Silverado Z71 Ext. Cab...
I am have an odd problem with my left turn signal. When i turn the left signal on it works ok untill i press on the brake and then the turn signal stays on constant. Even if the vehicle is off, If i press the brake the left signal comes on, the light on the dash and the actual signal lights.
any ideas or help would be great.
thanks....
itzmarko1 is offline   Reply With Quote
Old 01-27-2008, 08:59 PM   #2
1979_4x4_Plow's Avatar
1979_4x4_Plow is on a distinguished road
have you had anybody stand behind the vehicle and check your lights? the lights back there for the brake/signal has a high/low brightness level (dual filament) sounds like you have a bad bulb.
1979_4x4_Plow is offline   Reply With Quote
Old 01-27-2008, 09:50 PM   #3
junior3382's Avatar
And if that does not work, try the brake light sensor. It is located right on the brake pedal. I had the exact same issue with my S10. I thought I did it beating it up off road, and was afraid of what it was. Turned out to be a simple, inexpensive fix. Takes like two minutes to replace. Plow is probably right about the bulb itself, but if not, check there.
Lets get some mud on the tires...eh?!?!?
OWN:
1998 Chevy Blazer ls 4x4
4.3l Vortec V6
1998 Mazda B3000 SE 4WD
3.0L V6
3" lift
31x10.50 Liberator A/T's
junior3382 is online now   Reply With Quote
Old 01-28-2008, 12:35 AM   #4
one light being affected is usually a bad bulb or the fixture itself... i have come across a few that had bad fixtures
Old 01-28-2008, 04:23 AM   #5
Might also be a defective flasher unit, check bulbs first, front and rear.
Old 01-28-2008, 06:53 AM   #6
I have checked all the bulbs, and the right rear was blown but the problem still comtinued, so typical me I went to the auto store and changed every bulb front and back. Still nothing....
Old 01-28-2008, 08:31 AM   #7
does your bulb sit in a cap that twists into place with no wires? i know some of them taillight assemblys have like a circuit board that gets messed up in them is why i was mentioning the bulb or the fixture.
Old 01-28-2008, 09:52 AM   #8
stumpuller454's Avatar
stumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to behold
if you have a trailer plug check for corrosion, could be comming back through there, also check connections at distribution block (lh side of frame under truck facing backwards on a crossmember near rear of truck, connections could be bad, there
96 Z71 dies on left hand turn jemster69 Chevy Truck Forum 2 04-30-2007 07:44 AM
Any way to test a turn signal flasher? gunner1 Chevy Truck Forum 4 02-09-2007 01:56 PM
Turn signal cancels daytime lights TonyK GMC Truck Forum 7 10-24-2006 06:33 AM
turn signal switch 79ford4x4 Ford Truck Forum 2 09-30-2006 07:26 AM
