do you know relays well enough to "jump" them? could do this to see if you can hear the pump not running, you can also try giving the tank a good boot or 2x4 trick maybe pump is toast, if you hit bottom of tank it may become "temporarily" unsized and you truck may run, if still nothing your gonna have to check for fuel pressure at engine, someone may have to help me out hear as to the location of the test port but i`m thinking near the throttle body anyway, should have a shrader type fitting with a plastic cap kinda like your tires do, anyways check for pressure there, 50-60 psi with key on of coarse, if no squirt very likley to pump, isa good idea to check for power and ground at plug in to pump, (is very ***tty to get at), actually easier with tank out but, you know,...Well this may help you"if" itsa pump problem, let us know how you make out!!
