Old 01-31-2008, 07:45 AM   #1
Kingcool's Avatar
Kingcool is on a distinguished road
'90 G20 5.7L Running Bad
I have a '90 chevy G20 5.7 TBI. Hard starting, stalls couple of times. When finally moving runs pretty good. When it gets halfway warm bogs big time, you can push down on gas pedal 2 inches w/no response. Only way to get acceleration is to put it on the floor, but it still bogs. When it is fully warm runs pretty good for the most part. If you stop the engine for 15mins then restart, engine runs really bad, shakes sputters won't accelerate. If you let it run that way for 5min it clears up and runs pretty good. I have changed fuel filter, air filter, cap, rotor, plugs, wires, had injectors cleaned, timing set, checked for vaccum leaks. Computer puts out no codes. Any HELP would be appreciated. THANKS...
Kingcool is offline   Reply With Quote
Old 01-31-2008, 10:29 AM   #2
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
i'm wondering if your minimum air rate is too low
you'll have to knock out the idle screw plug and turn in 1/4 turn, not too much and recheck linkages, best to do with a scanner when warm, check iac counts you want 10-20, would also check iac pintle for dirt
replace egr valve, spring in valve gets weak causing stumble/lag
jimbo543 is offline   Reply With Quote
Old 01-31-2008, 03:15 PM   #3
strokin350's Avatar
strokin350 is on a distinguished road
i had a simalar problem on my 92 gmc and it turned out to be the coolant temp sensor.
strokin350 is offline   Reply With Quote
Truck won't keep running bigbassmann Dodge Truck Forum 15 11-22-2007 02:16 AM
Rough Running smokejumper0902 GMC Truck Forum 3 03-13-2006 06:46 PM
running rich vanhal Chevy Truck Forum 1 12-20-2005 05:02 PM
Running rough Daniel B GMC Truck Forum 4 12-20-2005 02:50 PM
running Bad stryder Dodge Truck Forum 0 12-17-2005 07:26 PM
