Results 1 to 8 of 8
Thread: 1994 k1500 - help ...no brake lights
    Jan 2008
    3
    94 1500 4x4 just pulled truck into shop ,no brake lights,,both left and right turn signals work fine.blew a fuse when turning on 4 way hazard lights, change fuse and still no brake lights,,where do i satrt with this one?
    if turn signals are working then the bulbs are ok.the fuse it blows is the stop hazard fuse think its number 1 in the fuse box,maybe a short or brake light switch?
    Senior Member junior3382's Avatar
    Mar 2007
    Currently, I live in Lancaster county, Pennsylvania.
    3,171
    Do the parking lights work along with the turn signals and 4-ways?
    Mar 2007
    Pennsyltucky
    1,143
    multi-function switch...
    Joe
    1962 Scout 80 parts I guess
    1966 Scout 800 resto job
    1996 P30, 6.5 NA Mac Mobile
    whole lot of buicks
    crabtruck's Avatar
    Jul 2007
    5,566
    Welcome to the forum duramac.
    You are right on the bulbs being ok. Thought the stop fuse was bottom center.
    Pull the hazard flasher out (not turn flasher), replace the 15A fuse.
    Verify turn signals work. Check that fuse does not blow and high stop light works.
    If not I would suspect you have water in your high stop lamp fixture.
    If it does work, bad haz flasher or turn/haz combo switch as Joe suggested.
    Or something in the wiring connecting them shorting (brown wire)
    May 2007
    Oregon
    4
    My 94 Silerado had the same problem. I believe It was a recall back in the day. Brake switch under dash near the brake pedal OR check yer wiring harness at rear end. I "accidently" bolted a hitch to my harness and created a short there.
    crabtruck's Avatar
    Jul 2007
    5,566
    I believe the recall was for "wrong polarity" on the wiring to switch and the possible hazard was fire. Should work fine until that point.
  7. #7
    Jan 2008
    27
    My 97 has a fuse box under the hood also ,with another brake light fuse.
  8. #8
    crabtruck's Avatar
    Jul 2007
    5,566
    94's didn't have fancy underhood fuse boxes LOL Only fuse there was fuel pump.
  1. 2001 S10 Blazer Brake lights won't go off
    By Larry's S10 in forum Chevy Truck Forum
    Last Post: 01-15-2008, 07:19 AM
  2. 1991 1500 Brake Lights Stick On?
    By harleypapa in forum GMC Truck Forum
    Last Post: 11-09-2007, 07:02 AM
  3. Brake Lights always ON!!!!!
    By nnunez in forum Nissan Truck Forum
    Last Post: 10-12-2007, 01:51 PM
  4. 1995 CHV k1500 No brake lights / brake switch
    By gejandsons in forum Chevy Truck Forum
    Last Post: 07-10-2007, 08:28 PM
  5. Help on Brake lights 4 a 99 Tahoe 4x4
    By cave in forum Chevy Truck Forum
    Last Post: 12-23-2004, 10:25 PM
Tags for this Thread
