Old 02-04-2008, 11:46 AM   #1
Idler Pulley?
How can you diagnose which pulley is bad?
I hear a squeek and it gets louder when I idle the engine.
Old 02-04-2008, 12:04 PM   #2
This is a good question with a simple solution.
Find a spray bottle that has a "stream" setting, or one that can be adjusted to stream plain water.
Spray the clean plain water on the pulley, or bearing that you believe is suspect. You do not want to get water all over the place, just enough on a local area to isolate the squeek. The plain water will allow just enough lubrication to make the squeek go away for a short period of time, and not cause a mess like oil will. Isolation is a snap this way.
This method is easy and clean while still very effective.
Good luck troubleshooting.
Old 02-04-2008, 02:04 PM   #3
Hayden's Avatar
Could also be your belt. Mine looked brand new (serpentine) but had another one around and changed it and all was quiet again
Old 02-05-2008, 11:05 AM   #4
You know, someone suggested to use WD40. But I'd hate to slip up and have WD40 all over the belt.
Thanks for the info......
Old 02-05-2008, 11:06 AM   #5
I dont think its the belt since it sound like a bearing.
But I am going to change the belt as well........
thanks......
Pulley Fresh96 Ford Truck Forum 5 04-11-2007 07:35 PM
