Old 02-08-2008, 08:59 AM   #1
chucky6965 is on a distinguished road
Angry 1999 Silverado "Banks too Lean"
I have a 1999 Silverado and the service light keeps coming on. The truck has 137,000 miles on it I had changed the spark plugs when all this started. I have change the mass air flow sensor, new fuel filter all new oxygen sensors and have checked for any vac leaks using soap and water and sprayed carb cleaner around the intake. The truck runs great and idles good and the gas mileage was poor before I had changed the spark plugs and at that time the gas mileage went up and it still is running good. Its just the service engine light will no go off. Codes received are P0171 and P0174. Both banks too lean… any ideas?
chucky6965 is offline   Reply With Quote
Old 02-08-2008, 03:36 PM   #2
72'CaminoKid's Avatar
i want to say maybe something with hte cats but not positive
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 02-08-2008, 05:49 PM   #3
i would check for exhaust leaks before your o2 sensor. also the cat like camino said. what brand of o2 sensors did you buy? most non-oem sensors are junk right out of the box.
i'd rather be hunting
Old 02-08-2008, 09:31 PM   #4
jdfenske is on a distinguished road
how would one check a vacuum leak with soap and water?
i beleive the first set of o2 sensors regulate fuel injectors with air intake.
2nd set check to see if cats are working. i think.....
350 30 over
cats and X pipe
4L60E w/shiftkit
jdfenske is offline   Reply With Quote
Old 02-09-2008, 11:04 PM   #5
NCroadracer's Avatar
NCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud ofNCroadracer has much to be proud of
Most likely it will be your intake seals leaking vacuum... Spraying the intake has little to no effect on it, unless you can watch the Ho2s readings with a scan tool. they usually leak at the bottom of the ports where you can't really spray anything.
NCroadracer is offline   Reply With Quote
Old 02-10-2008, 07:17 PM   #6
emzornes is on a distinguished road
Banks lean
Have you checked the fuel pressure yet? That would be where I would start a weak fuel pump causes this very problem and sets the same codes.
emzornes is offline   Reply With Quote
The "lift bed" Procedure for R&R tank mounted fuel pump? Shox Chevy Truck Forum 4 02-16-2007 12:01 PM
01 silverado "security" message light navmedic1 Chevy Truck Forum 2 01-30-2007 09:14 PM
2000 Silverado - "Piston Slap" Snowdooer Chevy Truck Forum 20 11-19-2006 10:23 AM
"99" Silverado harness diagram, anyone? keith2441 Chevy Truck Forum 1 11-07-2006 05:29 AM
2000 silverado 1500 5.3 "miss" at idle WDDOBLER Chevy Truck Forum 7 02-02-2006 06:44 PM
