Old 02-15-2008, 08:20 AM   #1
stumpuller454's Avatar
stumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to beholdstumpuller454 is a splendid one to behold
Air Flow
hey guys wondering if anyone has fooled around with larger throttle bodies and/or airflow sensors ona vortec engine, i`v heard good and bad, i`ve more commonly heard that to use bigger injectors with the body and sensor upgrade. am considering multiple options here, ie bigger throttle body, airflow sensor, air intake, cam and headers, thanks
Old 02-15-2008, 08:28 PM   #2
i wish somebody messed with their truck first, and could tell me, oh well gonna get a price on everything and report back in a month or so, gonna try it all i think!
Old 02-15-2008, 09:07 PM   #3
rdillon's Avatar
rdillon is on a distinguished road
With the right amont of money you can go as fast as you want to. I would not blow money on a air intake system for $200. Instead go to that notorious online auction site and look around. I found a set of bigger injectors for cheap using your trucks description. Shes 10 years old there are alot of performance parts out there. Again alot of them give you rear wheel horsepower ratings.
Whipple 1993-2002 454/502 Magnum EFI/MPI Supercharger Kits
2005 Chevy 4x4 LS 5.3L BFG KO's
Sucks gas but hauls a**
1985 F150 5.0L EFI
Old and slow. Used as a decoy when parked at work 2 weeks at a time... Really not a bad truck 16 mpg
rdillon is offline   Reply With Quote
Old 02-16-2008, 04:01 PM   #4
jdfenske is on a distinguished road
i put on aftermarket heads
i knew someone with the same heads and cam i'm using and they went the extra effort and money and bought higher flow injectors, and didn'dt make much difference. i mean, probably 10hp, but nothing noticeable without a dyno and fancy measuring tools.
i'm using oversized intake and exhaust valves, along with a low rpm cam with a high lobe. took 2 or 3 weekends and using a dremel and hogged out the passages and all thet good port and polishing stuff. made quite a difference from 800 to about 3500, anything past that it gets gutless. but these days everyone uses oversized tires and drives in overdrive, so, i figured i'd shoot for torque at lower rpm and set it up to breath. using the factory intake throttle body and a k&n. oem sensors and injectors.
but you ask any engine rebuilder, and from experience myself, NOTHING will beat an engine with fresh rings and crisp valves for horsepower. a fresh 305 will easily keep up with a old tired 350.....
350 30 over
cats and X pipe
4L60E w/shiftkit
jdfenske is offline   Reply With Quote
Old 02-16-2008, 07:11 PM   #5
yeah, im actually gonna call a place nearby that does custom ecm tuning and see if they have done anything with the 454`s, then see which direction to go, i just wanna drop some jaws and **** of some deisel drivers!
mass air flow sensors smylesM04 GMC Truck Forum 0 12-29-2007 03:11 PM
Max Air flow Sensor cajunwoodrick GMC Truck Forum 8 05-03-2007 04:30 PM
mass air flow sensor screen?? gki General Truck Forum 10 11-14-2005 11:38 AM
the loudest high flow cat out there????? cambo Chevy Truck Forum 4 03-01-2005 09:34 AM
