Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 1997 GMC 1500 - new heater blower not working
    Senior Member PickUpGirl787's Avatar
    Dec 2006
    Illinois
    711
    I have a couple of questions for ya. I put a new blower motor
    in my truck thinking that it would fix the squealing noise it made,
    after i put it all back together I turned it on and got nothing.
    Took the test light to it and found that there was power to it and everything,
    I'm thinking it could be the switch, because I have had some problems
    with that too. staying on after I turned the truck off etc...
    does anyone have any ideas and should I get a new switch from the junkyard
    or should I call up Napa and just get a new one?
    Ashley
    My first truck was a 1988 Chevy 1500 with the 305
    My new truck is a 1997 GMC 1500 with the 350
    Jul 2006
    3,690
    If you have voltage like you stated, then the switch is not the problem.
    Did you verify that the motor worked prior to the install?
    Dec 2005
    307
    If you change the swithc, I believe that I have seen the switch at the "help" section in Auterzone......
    But your switch may not be the problem if you have juice at the fan.
    Senior Member 03chevy's Avatar
    Dec 2006
    jax,fl
    1,244
    make sure you didn't blow a fuse too.
    Dec 2006
    Illinois
    711
    fuse is ok. ill look again maybe ill take it all apart and put it all back together, gives me something to do
    Ashley
    Dec 2007
    58
    Shoot if you have that much time to waste feel free to work on my truck anytime. I always have something new to work on. I would make sure the blower works. It might of been bad when you put it in.
  7. #7
    Dec 2006
    Illinois
    711
    I have no school this week so im really bored, Trying to pick up extra shifts at work but in the mean time its me and the remote watching lifetime movies or freezing outside working on the stupid heater
    Ashley
  8. #8
    crabtruck's Avatar
    Jul 2007
    5,566
    Remember Ash, hot is only one side of circuit, check your ground path is good.
    Before pulling the blower, you could try a couple other things.
    With it all hooked up, key on, eng off, see if batteery voltage drops when you turn on fan.
    If it does, your connections are good.
    If not, may be connections, but disconnect the hot (& key out)
    and ohm the blower hot (wire from motor, not switch) to ground.
    If nothing, ohm across the blower itself.
    If good, try jumping the disconnected blower wires straight to the battery for a second.
    Good practices says use a fused wire to do the jump.
    If ohming across the blower by itself shows its open, the blower is bad.
  9. #9
    Feb 2008
    5
    Sounds like you got a short somewhere. Make sure your ground wire is attached. Any rust or paint where the wire goes means you aint got a good ground.
  10. #10
    Senior Member silverhairdeere's Avatar
    Feb 2008
    land between the lakes tn
    1,831
    depending on on the year or if it has airconditing , i believe there is a resistor that controls the motor speeds
    silver hair deere
  1. block heater
    By hick in forum Chevy Truck Forum
    Last Post: 01-19-2008, 09:48 AM
  2. heater controls
    By vanhal in forum Chevy Truck Forum
    Last Post: 01-30-2007, 06:56 PM
  3. AC/Heater Problem
    By 3500hauler in forum Chevy Truck Forum
    Last Post: 11-20-2006, 08:44 PM
  4. heater/AC fan
    By brucetnt in forum Dodge Truck Forum
    Last Post: 07-03-2006, 06:21 AM
  5. 1998 chevy z71 heater motor intermittent
    Last Post: 12-05-2005, 06:59 PM
