Old 02-26-2008, 11:59 AM   #1
ironhorse is on a distinguished road
Transmission help
My 1994 chevy truck has a hard shift in all the gears and "BANGS" when it shifts into 2nd or 3rd and back down. What could this be? I bought it used and since then have replaced 2 busted motor mounts and a busted rear transmission mount (thinking this was the problem) but the banging and hard shift still exist. Any ideas? (A/T)
ironhorse is offline   Reply With Quote
Old 02-26-2008, 12:11 PM   #2
03chevy's Avatar
03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future03chevy has a brilliant future
hope this helps to get you started.PriorityActionPart TypeCause1Inspect Transmission (Capacity) Incorrect transmission fluid level 2Inspect Transmission Fluid Type Improper type or level of transmission fluid. 4Inspect Transmission Cable Detent (A/T) Damaged, worn, or incorrectly adjusted transmission detent cable. 5Inspect Transmission Cable Shift (A/T) Worn, or incorrectly adjusted transmission shift cable. 6Inspect Transmission Cable Shift (M/T) Worn, or incorrectly adjusted transmission shift cable. 7Inspect Transmission Control Solenoid Damaged or faulty transmission control solenoid or circuit. 9Inspect Transmission Kickdown Solenoid Faulty transmission kickdown solenoid or solenoid circuit. 10Inspect Transmission Modulator - (A/T) Worn leaking or faulty transmission modulator valve or vacuum system. 12Inspect Transmission Shift Linkage (Manual)Broken or improperly adjusted shift linkage. 14Inspect Transmission Temperature Sensor Damaged, worn, or faulty transmission temperature sensor or transmission temperature sensor circuit. 15Inspect Transmission Filter (A/T) Clogged or dirty transmission filter. 16Inspect Transmission Control Module Damaged or faulty transmission control module or circuit.
Old 02-26-2008, 12:19 PM   #3
Welcome to the forum ironhorse.
Probably wouldn't hurt to read the trouble codes for ideas too.
Have you pulled those yet ?
Old 02-26-2008, 01:46 PM   #4
I haven't pulled the trouble codes... don't know where to get them.
Old 02-26-2008, 01:48 PM   #5
I will start checking these things out. Thanks. Just to let you know that the A/T has been rebuilt in hopes of fixing the problem.
Old 02-26-2008, 02:15 PM   #6
my83432 is on a distinguished road
This could be as simple as a shift kit was added. If the builder was really good they might notice it but not if they' re not looking for it.
my83432 is offline   Reply With Quote
Old 02-26-2008, 03:26 PM   #7
Trouble codes can be read for you by a local parts store for free maybe.
Otherwise do it yourself. Simple proceedure, you need a pencil and paper,
and you need a jumper wire (paper clip).
With the key on and the engine off, jump socket holes "A" and "B" of the ALDL.
That's located under the edge of dash, pointed at you, near brake release.
When you do that the check engine light will flash in a pattern of codes.
It will flash(blink) the codes it has stored and then will repeat the list of them.
In the event that no codes are stored, it will only flash a code twelve (1-2).
Let us know what codes you see and we will help with translation.
In this picture the ALDL connector is almost dead center.
Old 02-26-2008, 06:31 PM   #8
jdfenske is on a distinguished road
odbi is quite limited for transmission information.
might need to attack it old school.
sounds mechanical.
350 30 over
cats and X pipe
4L60E w/shiftkit
jdfenske is offline   Reply With Quote
Old 02-27-2008, 12:56 AM   #9
Agreed that OBD-I is primitive but I do have a list of codes for it.
Mostly rooting around for more info.
Old 02-27-2008, 08:43 AM   #10
only the trouble code 43 came up (other than 12 of course)
c-6 transmission colocat Ford Truck Forum 0 11-25-2007 05:30 AM
Help with transmission pscheers Chevy Truck Forum 8 10-06-2007 12:53 PM
transmission gone? eganracing Chevy Truck Forum 16 09-11-2007 07:34 AM
Transmission HELP! Cali Hough Chevy Truck Forum 11 06-07-2006 04:43 PM
Transmission ? skully Chevy Truck Forum 2 01-28-2006 09:33 AM
