| Junior Member Join Date: Feb 2008
| tire cupping my 1998 z71 front tires are cupping on the edge. When I replaced the old set (for the same reason) I had alignment checked Now the new set of tires are ruined. Was told the idler arm is the problem and even replacing it won't do much good for very long. Any ideas on the problem |
| Welcome to the site; This should be an easy fix. Your shocks are no longer controlling the tire, and they are skipping along causing the cupping. Scallops will be a result of a poor alignment, cups are from the tire bouncing along. Remove a shock, and check for resistance, you will find worn shocks. Good luck |
| Tire Rub | texasram | Dodge Truck Forum | 3 | 02-19-2008 08:42 PM |
| tire question?? | Truckin03 | Chevy Truck Forum | 5 | 11-29-2007 11:44 AM |
| Tire help. | ragtagf150 | Ford Truck Forum | 13 | 01-26-2007 10:18 PM |
| tire size | johnkraus7 | Dodge Truck Forum | 2 | 01-21-2007 09:46 AM |
| tire ? | joey40949 | GMC Truck Forum | 3 | 01-24-2006 12:05 PM |
