Old 03-06-2008, 10:09 PM   #1
devasa is on a distinguished road
Question 1997 350 engine
I have a 1997 350 5.7 in my chevelle. What is the spark plug gap, is it.035 or .045. What should the timing be, TDC or how many degrees before top dead center. The motor is stock.
devasa is offline   Reply With Quote
Old 03-06-2008, 10:38 PM   #2
NCroadracer's Avatar
NCroadracer will become famous soon enoughNCroadracer will become famous soon enough
Here are some specs for your 97 5.7 L.... As for the timing, depends on what you're using for an ignition system.
Engine Mechanical Specifications (5.7 L)
Application
Specification
Metric
English
General Data
  • Engine Type
V8
  • Displacement
5.7 L
350 CID
  • RPO (VIN Code)
L31 (R)
  • Bore
101.63 mm
4.0012 in
  • Stroke
88.39 mm
3.480 in
  • Compression Ratio
9.4:1
  • Firing Order
1-8-4-3-6-5-7-2
  • Spark Plug Gap
1.52 mm
0.060 in
  • Oil Pressure (Minimum at Normal Operating Temperature)
42 kPa at 1,000 RPM
125 kPa at 2,000 RPM
166 kPa at 4,000 RPM
6 psig at 1,000 RPM
18 psig at 2,000 RPM
24 psig at 4,000 RPM
NCroadracer is offline   Reply With Quote
Old 03-07-2008, 01:22 AM   #3
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Hey NC, is that last spec a typo ? My 5.7 specs it at 40psi @ 4,000rpm
Old 03-07-2008, 05:49 PM   #4
No... Those are the Minimum acceptable specs. Seems low, but not a type-o.
Old 03-12-2008, 07:17 PM   #5
Sneakysportsman's Avatar
Sneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really niceSneakysportsman is just really nice
One more thing, make sure your plugs are long enough to go all the way into the combustion chamber. Argued with an idiot @ A*^$3^E Auto about this. Make sure you buy plugs of the proper thread length.
Sneakysportsman is offline   Reply With Quote
Old 03-12-2008, 10:18 PM   #6
Went back to check up on my reading.
Turns out it wasn't a typo
It was a read-o, you were again right.
Old 03-13-2008, 07:00 PM   #7
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
I would run about 10-12 initial, 38 total all in at 2500 or so.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Engine misfire detected engine code HELP Airforce wrench Chevy Truck Forum 2 02-21-2008 08:13 PM
v6 1997 3.9 Question mojoe Dodge Truck Forum 1 03-08-2007 02:50 PM
1997 chevy c-1500 texasjack Chevy Truck Forum 7 12-20-2006 09:39 PM
1997 Dakota Engine Swap sgtbraddick Dodge Truck Forum 2 07-27-2006 10:37 AM
1997 Sierra Z-71 ?'s jpitbull96 GMC Truck Forum 4 03-02-2005 10:22 AM
