Old 03-07-2008, 09:48 PM   #1
jobberone is on a distinguished road
1976 Cheyenne steering column problem
Loaned the truck to my son and when it came back I couldn't turn the key the second time I cranked it up.
It's a little difficult to very difficult to turn the key. Most of the times it won't go all the way to the extreme crank position. At times it may go but then not engage the starter.
I'm sure this is not an uncommon problem. I'm waiting on a service manual but thought there may be something I could try until it gets here. If you can get it to go to the proper position very occasionally the starter turns over and the truck cranks up and runs fine.
If is a tilt steering wheel but I think the column is stock. There is a vette steering wheel though.
Thanks
jobberone is offline   Reply With Quote
Old 03-08-2008, 04:03 PM   #2
stumpuller454's Avatar
i had the eact same problem on my 80 tilt wheel, my factory service manual was very helpfull, cant remember the name of the part but "it" was cracked and sticking then eventually broke, it was the peice that the pin on the key cylinder went into and pulled the ignition switch, had to order part from GM was abit of a pain to change required alot of dissasebly of column, think i need a puller for tilt`s pivots removal,... it was a really long time ago. your manual should tell you what the part is, is "kinda" shaped like a "key" hope this helps abit!
Old 03-08-2008, 06:20 PM   #3
Thanks. figured I'd have to disassemble the thing. I'm waiting on a manual.
rattle in steering column ol_hounddog Chevy Truck Forum 14 03-06-2008 09:44 PM
Steering Column Housing TZR2 Chevy Truck Forum 4 05-05-2007 12:37 AM
steering column swap out help viperman Chevy Truck Forum 2 04-30-2007 02:15 PM
Changing a steering column NC4W Chevy Truck Forum 3 01-09-2007 07:11 AM
Steering column vibration in 92 4x4 mochester Toyota Truck Forum 3 05-20-2006 10:27 PM
