| 1989 chevy 1 ton dually overheating..any ideas why? I have a 1989 Chevy 1 ton dually with a 454 v8 it has been overheating a lot recently. When it overheats the manifold glows red it is so hot. I have checked the radiator, thermostat, water pump, computer, fan clutch, & auxillary fan, but all are working fine. I think it may either be the exshaust causing it to overheat or a computer programming glitch. Does Anyone know what might be wrong?? |
| Is the fan howling when it gets above 220 degrees, it should be! You didn't say which state so if you subject it to salt etc. and its over 4 yrs old the cooling fins in the radiator core may be degrading and what you think is good in fact is not. If the exhaust is black the throttle body might need attention (like a flooding carb). just some thoughts |
| has it lost power? maybe your cats are plugged up |
| Senior Member Join Date: Mar 2007 Location: Pennsyltucky
| glowing exhaust parts ussually mean one of a few things- 1. plugged cats 2. ignition timing that is way retarded 3. very lean condition? Whats the motor temp? hot exhaust doesn't neccessarily mean overheating.
__________________ Joe 89 K2500 Chevy, Wee-Oh-five 294K miles 1962 Scout 80 parts I guess 1966 Scout 800 resto job 2005 Chevy 2500HD Short cab long box DURAMAX 1996 P30, 6.5 NA Mac Mobile whole lot of buicks |
| On all of the 454's I've owned when you saw a glowing exhaust it meant the engine was leaning out. |
| Full Member Join Date: Feb 2008
| air trapped in the cooling system will make it hot....it sounds like the top of the motor is'nt getting coolant,,also could be a blocked runner or a bad head gasket |
| Junior Member Join Date: Dec 2007
| I had a blazer with a 350 that did the same thing. Belive it or not we tried everything to fix it, guess what it was bad radiator cap-- looked good but as soon as we replaced it. It cooled fine with no more problems. |
| i would think bad cat...causing the problem but as stated above retarded timing will do it and leaning it out will do it as well. did you pull the air cleaner and check the injectors? (if 89 454s were injected im not sure ive only worked on 350s) |
| 98 chevy 3500 dually 454 no fire ? | minnesota jim | Chevy Truck Forum | 4 | 01-24-2008 10:28 AM |
| 1989 Chevy S-10 won't start | raydqt | Chevy Truck Forum | 1 | 01-07-2008 01:39 PM |
| 1987 chevy one ton dually for sale | skip | Chevy Truck Forum | 0 | 05-21-2007 05:07 AM |
| Ford dually, GM dually, or Dodge dually? | josnj1 | Ford Truck Forum | 7 | 10-02-2006 08:12 AM |
| 1989 chevy value | 396chevy | Chevy Truck Forum | 6 | 09-27-2005 10:23 PM |
