| Junior Member Join Date: Mar 2008 Location: Alvin Texas
| 4l80e tran help Hello all i have a 2000 chevy 3500 2 wheel drive with a 4L80E trans its shifts great and into overdrive seams like after it warms up that it will slip out of over drive the only way i can get it to work again is to turn off the key and start it up again and than it will work fine Note i dont have to stop the truck i can do this while driving down the road !! ,that kinda tells me its mabe a solonoid ?? i removed to pan to change the filter the fluid is not burnt and the filter looks good i will be chainging it anyway what i found in the pan stuck to the magnet is a small spring about 2 1/2 in. long with a L shape at one end and a loop at the outer end .its a small thin spring and does not look broken,the inside of the pan was clean and no metal, any help would be Great Thanks !!! i know this is a long post this seams to be a normal concern for this trans |
| Hey Old guy, from another old guy ! Welcome to the forum. Streching my knowledge with trannies here, but it sounds like it might be the spring off the control valve body holding the plug for the checkball behind the 3-4 valve. Whatever it is, you know dropping parts is not a good thing. I would suggest pulling codes and finding where it came from before turning the tranny again. |
| Found out what the spring was, goes to the Park arm ,went and kissed up to the local GM tech Cost me a Whatabuger |
| Boy, talk about the dealers overcharging ! |
| 4L80E Transmission Problem | fbhart@wk.net | Chevy Truck Forum | 10 | 08-25-2009 09:06 PM |
| 4L80E TC locks up all the time | rsharb | Chevy Truck Forum | 1 | 12-04-2007 12:37 PM |
| 4L80E slipping in O.D. 2000 2500 4x4 | flippin45 | Chevy Truck Forum | 0 | 07-09-2007 11:22 PM |
