| Full Member Join Date: Mar 2008
| Oil pressure gauge problem I recently bought a 350 engine (year-1982) from a wrecking yard. The brass piece at the rear of the engine where the oil pressure gauge mounts was broke off flush with the block. Does anyone know how to fix this or should I just plug it up and go without the gauge? The engine is going into my 1976 K20. |
| you can get a set of easy-outs and unscrew it out and put a new sencer back in
| Ditto to the ez-out. being brass it should not be frozen in there probably just brok off when they removed the engine. Should be fairly easy to remove. by the way. You really don't ever want to go without an oil pressure gauge.
| Thanks Thanks alot guys. I will see if Napa has them when I go get my gaskets.--Steve |
| GRABIT Damaged Screw Remover Check this out I think Sears sells something like this. |
| | #6 | |
bought my 94 dakota. oil gauge never worked. don't have any intentions to fix it either. burns a quart every 5000 miles, and by then it's changed anyways. in my opinion, if lifters collapse or rods start hammering, gauge or not, something's gone wrong. i think oil pressure gauges are way overrated and inaccurate. i think most people forget that's the pressure before it goes through the engine. 99% of the time that's not the pressure at the crankshaft, unless it's just rolled off the lot.
__________________ 1996 Z71 white shortbox tinted 350 30 over cats and X pipe Alumhds ported 210 cc runners 62 cc chambers 2" int 1.550" ex crane lift; 580/580 duration; 216/222 4L60E w/shiftkit | |
| Full Member Join Date: Jan 2008 Location: Salt Lake City, UT
| i was 4 wheeling in my 73 and a coupling in the oil pressure gauge line came apart.. sprayed oil everywhere and i wouldnt have known if i didnt see the gauge go to zero. maybe not accurate, but it saved me from losing all the oil through that line. my name is patrick, and i approve of oil pressure gauges.
__________________ 73 K20 4spd manual 6" w/35x12.50 BFG's 95 Tahoe LT 2dr/4WD 6" w/35x12.50 BFG's |
| hahahahahahaha
| in my opinion, if lifters collapse or rods start hammering, gauge or not, something's gone wrong. i think oil pressure gauges are way overrated and inaccurate. i think most people forget that's the pressure before it goes through the engine. 99% of the time that's not the pressure at the crankshaft, unless it's just rolled off the lot. i totally disagree with you. an oil pressure guage is just as important as a temp guage which is why its there in the first place. |
| Oil Pressure Guage Problem | hostdave | Dodge Truck Forum | 0 | 02-20-2008 07:25 AM |
| Problem with my 2003 chevy silverado oil pressure gauge | a1badboy | Chevy Truck Forum | 1 | 06-08-2007 11:05 AM |
| Problems with my 2004 chevy silverado oil pressure gauge | jorrmadog | Chevy Truck Forum | 5 | 04-11-2007 05:55 PM |
| gas gauge | bassmaster969 | GMC Truck Forum | 7 | 12-19-2006 10:00 AM |
| 1981 C-10 Fuel Gauge problem | DaleP1981 | Chevy Truck Forum | 2 | 10-20-2006 05:53 PM |
