| Full Member Join Date: Jan 2008 Location: Salt Lake City, UT
| power locks 95 tahoe 4wd power locks, keyless entry my locks don't work ever since i had the driver door replaced by a body shop.. had them working for about a week then they stopped.. i can hear the click from under the dash when i push the button, but get nothing at the actuator in either door, from either switch (pulled the door panels, nothing even twitches, so i know the rods aren't jammed or anything). All fuses are good. where should i look next?
__________________ 73 K20 4spd manual 6" w/35x12.50 BFG's 95 Tahoe LT 2dr/4WD 6" w/35x12.50 BFG's |
| I would take it back to the most body shops warrenty there work for the life of vehicle. But it does sound like the rod came loose. |
| Try this, the cig fuse is not the only power here: Look for output from the power accy CB (30A). Should go through convenience center (C) on ORG wire to both the (A) Batt term on keyless and (C) on relay. If you pull the relay, that terminal should always be hot, even key off. Relay will operate even if the contact is dead, so don't be fooled. Probably quickest to check for that power at relay first. LtBlu(F)lock and Wht(A)unlock will be hot when you hit switches. Blk(D) is ground. Gry(E) and Tan(B) are lock motor pair. I can PM a diagram if you really need it. I'm guessing either bad relay or open in that ORG supply wire. |
| thanks for the info thanks again!
| door locks ? | teemsta | Chevy Truck Forum | 11 | 08-02-2007 05:54 AM |
| Power Door Locks | WOT | GMC Truck Forum | 2 | 07-27-2007 05:00 AM |
| 93 silverado 1500 power door locks | che | Chevy Truck Forum | 3 | 11-20-2005 10:52 PM |
| power door locks 2000 Tahoe & 94k1500 | neo | Chevy Truck Forum | 0 | 03-12-2005 07:22 AM |
