Old 03-17-2008, 08:26 PM   #1
AKLAMIKE is on a distinguished road
Stuck Brake
I have a 1992 chevy pickup the left front brake sticks,I replaced the caliper,she drove fine on a short test drive the first day but today the brake stuck again but worse now it got red hot in less than a mile,help
AKLAMIKE is offline   Reply With Quote
Old 03-17-2008, 08:46 PM   #2
stumpuller454's Avatar
stumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud ofstumpuller454 has much to be proud of
does you vehicle have abs? maybe its something do do with that system, or maybe your porportioning?balence system? im not too sure if it controls front side to side, but front to rear for sure, does the passenger front apply and release? an rear?
Old 03-17-2008, 08:52 PM   #3
jarhead2001 is on a distinguished road
are the rubber brake lines original if so mine was causing the fronts to drag replaced the lines dramaticly improved braking
jarhead2001 is offline   Reply With Quote
Old 03-17-2008, 11:50 PM   #4
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Welcome to the forum AKLAMIKE.
More info would be helpful. Seven different kinds of basic pickups in 92.
What model, size etc do you have? Does it have ABS or RWAL ? 4w or 2w?
Why did you replace the caliper in the first place ? symptoms??
Old 03-18-2008, 06:34 AM   #5
Has the brake fluid been changed? If it never had leaks or major problem the fluid gets like molasses. When you bled the calipers did you do it till fresh fluid was present or just no air coming out? If the fluid is bad it takes a lot of pressure on the brake pedal to bleed it and then gets easy. This of course if you a a poor person like me and don't have a pressure bleeder sitting on the shelf
Old 03-18-2008, 06:45 AM   #6
03chevy's Avatar
i agree with jarhead2001 people don't think about the rubber hoses that feed the calipers going bad. change both and bleed the hole system and your problem will go away
Old 03-18-2008, 12:07 PM   #7
I agree. Replace the flex hose.
Old 03-18-2008, 12:46 PM   #8
mod-o-tator
it could be a number of things. i would replace the rubber hose, if it's original. i would also check to make sure the slide pins are not siezed up and are well greased.
how does the rotor look? is one side worn more than the other? if the outer looks worn more than the inside, that would indicate the slide pins.the fluid would exit the caliper piston and the inside pad would disengage contact with the rotor and the outside pad would remain stuck to the rotor.
if the hose was bad, then the fluid would not be allowed to leave the caliper piston and both pads would be in constant contact with the rotor.
also, replace that rotor once you fix your problem. it is most likely glazed over, or warped and not capable of doing it's job any more. if it is still within spec. you may be able to have it turned.
member map add yourself
alldatadiy
Old 03-18-2008, 03:27 PM   #9
Thankyou
Thanx for all the help,my truck is a 2wd 1500 silverado no abs yes the brake fluid was thick so I did bleed it till clean fluid squirted out the reason I replaced the caliper was because I could not get the piston to move at all,also I messed up the rubber boot when I took it apart.A new one was only $15.00 so I replaced it thinking that would fix the problem.I think I will replace the line and bleed um again hopefully that will fix it and then I will see about the rotor,again thank yall for the help,I need all the info I can get
Old 03-20-2008, 10:23 PM   #10
Problem Solved
Replaced the hose drained out all the old fluid put in new fluid and bled the whole system,seems to have fixed my problem thanx
stuck in the mud... literally! peterbilt Off-Topic 24 09-30-2007 01:04 PM
Stuck in 3rd gear 1997 gmc sierra GMC Truck Forum 3 09-21-2007 03:48 PM
Please help, Im stuck 88YJGirlly Chevy Truck Forum 10 08-22-2007 10:19 PM
Gettin' stuck will4831 Off-Topic 11 12-07-2006 02:50 PM
stuck chevy350 Chevy Truck Forum 8 06-25-2006 04:11 PM
