Old 03-19-2008, 07:36 PM   #1
tonyvt is on a distinguished road
Help runs good cold misses bad hot 90 5.0efi
my 1990 Chevy 5.0L 5spd. runs good cold misses bad hot. For the first 3 or so miles it goes great...but then It pings and looses power and is worse at higher rpms. If I back off and dont make it work too hard its not bad. Its been doing this for a while but I havent been driving it much. In the past it would miss for a while then once it was full hot it would be ok. I havent had a chance to drive it too far yet to see if it will stop once completely warmed up. I just drove it home about 10 miles and once it started missing it didnt stop unless I backed off and drove like 45-50 in 4th gear. I think its related to mid temps?? Something with the fuel/ or timing at mid temp>>??? has over 160k miles...
I need this fixed.???
Thanks!!
tonyvt is offline   Reply With Quote
Old 03-20-2008, 07:02 AM   #2
03chevy's Avatar
when's the last time you did a full tune up? (air and fuel filter,plugs,wires, cap, rotor) or could be a number of things like knock sencer, cam shaft sencer, map sencer, mass air flow sencer.
Old 03-21-2008, 07:44 AM   #3
Do you have a check engine light on? If so you could pull any error codes stored. How long since you changed spark plugs? How long since you changed plug wires? Could be something to check.
Old 03-24-2008, 10:58 AM   #4
Ok so I found the coil was bad on Fri. it was arching like crazy. So I figured I found my problem.. NOPE> But it was really bad.
So now it runs just fine cold. As soon as the temp starts to come up it starts to ping/knock looses power. BAD So could it be a timing issue? What could cause this? It had new cap/rotor fuel filter. last fall.. It idles fine hot or cold .
No lights on.
Please help?? Thanks
Old 03-24-2008, 11:58 AM   #5
mod-o-tator
i would look at the temp sensor. i believe when they fail, they peg out all the way cold or all the way hot. so your truck thinks it is still cold when you have reached operating temps, causeing your misfire.
member map add yourself
alldatadiy
Old 03-24-2008, 12:01 PM   #6
Thanks!
I will today!
Old 03-24-2008, 12:48 PM   #7
IF my gage works could the sensor still be causing the problem ???
Old 03-24-2008, 04:01 PM   #8
mod-o-tator
it could be possible, here's a little reading for you.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
i would also look at the MAF sensor, it measures the density of the air. the colder the air, the denser it will be. if the MAf sensor is bad, your air/fuel ratio will be off, possibly causing your problem.
alldatadiy
Old 03-24-2008, 08:50 PM   #9
keithr0005005's Avatar
wait your saying its pinging...a lot of the time pinging can come from a poor grade of fuel. sooooooooooo we know these trucks from factory are designed to run off of 87 octane and if your pinging and running like **** when the truck warms up then my guess is your timing is slightly advanced. advanced timing requires a higher octane fuel for better combustion which can potentially explain your pinging and poor performance.
Old 03-28-2008, 01:17 PM   #10
FIXED!!
I cant belive it... It was a plug wire fell off cyl.2...
holy ****....
but I learned alot about testing my efi electronics...
98 S10 V6 Runs rough when cold after 5 miles runs great? STRAYDOG Chevy Truck Forum 17 01-24-2008 02:44 PM
Ok so I went to a new guy and it RUNS! PickUpGirl787 Chevy Truck Forum 9 01-11-2007 04:43 PM
94 K1500 Runs Rough When Cold tdyer Chevy Truck Forum 0 04-07-2006 06:32 PM
What is a good Cold Air Intake? rickards Chevy Truck Forum 12 12-07-2005 06:01 PM
Motor Sports Notebook: Jefferson misses cut for truck series start (Seattle Post-Intelligencer) trucknews Truck News (headlines) 0 11-18-2004 11:30 PM
