| Full Member Join Date: May 2007
| 1995 1500 Chevy K blinker (light) does not work I have a 1995 1500 Chevy K truck V6 and the rear drivers side blinker (light) does not work. I replaced the bulb and it worked "Once" and then it blew again. Is their a relay in the circuit or possible do I have a short? If anyone has any ideas I am open ears. Thanks so much in advance!! |
| I am confused, The BULB blew ? Would have to be a bad bulb, but never known anyone to find two. Did you ohm the bulb or see broken filament inside ? Did you check socket for power ? |
| is it a single pin or double pin bulb that it calls for. if you put the bulb in wrong it will cause it to get real bright then blow right after |
| 1995 1500 K Truck V6 | larbec7 | Chevy Truck Forum | 3 | 05-31-2007 10:20 AM |
| air bag light stays on 1995 1500 | larbec7 | Chevy Truck Forum | 12 | 05-30-2007 08:08 PM |
| 1995 Chevy Silverado 1500* 5.7,at*87,000 Miles | mrhaney | Truck Classifieds | 2 | 09-08-2006 05:43 AM |
| 1990 chevy 1500 problem e brake light | josh030181 | Chevy Truck Forum | 2 | 08-27-2006 12:29 PM |
| Front Blinker won't work | BcVulcan | Chevy Truck Forum | 11 | 06-25-2006 08:50 PM |
