Chevy Truck Forum - Chevrolet / Chevy trucks and their accessories forum. |
#4 (permalink) |
I'm assuming it started flashing because you jumped A to H.
If so, what you are really seeing is 1 long and three short (code 4) RWAL only stores one code at a time for that year and will repeat it. Reason that is good is because sometimes the first flash count is wrong but the repeats will be right. Code 4 is a grounded Antilock Pressure Valve Reset switch. Key off, disconnect the 4-wire plug from EBCM and ohm the C contact to ground. Pull Stop fuse for 30 seconds.(Clears code) Key on, measure the voltage on the module's 4-wire pins from "C" to "D". If you get 4v or more the pressure valve is a problem. If zero volts, the ECBM may be toast. Check your wires good and verify that code before spending money. |
#6 (permalink) |
crabtruck
i read your post on a similer issue on a gmc and tried your input (the code quit flashing) i unpluged the parking brake wires light stayed dim, next unpluged the one wire from the al block light stayed on, last the rwal upper plug and the light went off. Im asuming that most likly the brake controller is bad. thanks Justin |
| 2005 4WD Service Light | 1Rudeman | GMC Truck Forum | 3 | 11-02-2007 05:47 PM |
| Service Engine Soon light | ralphmorgan | GMC Truck Forum | 14 | 01-08-2007 04:39 PM |
| Service engine soon light | Sean Barrett | Introductions | 3 | 08-16-2006 06:37 AM |
| Resetting engine service light | mrwiglee | Chevy Truck Forum | 7 | 01-24-2006 09:50 AM |
