Old 03-22-2008, 04:30 PM   #1
grabon77 is on a distinguished road
Angry Power fading in and out
I have a 79" half ton 350. The problem started a couple of days ago, it acted like it was running out of gas, I put gas in it and it was fine. Turns out gas was not the problem. Now it will barely run, it is fine for a couple of seconds then acts like it is bogging out heavily, then it comes back for a couple of seconds, and so forth and so on. Eventualy it will die with what sounds like a small backfire. It will then start right back up and repeat the process. I can't get it over about 25 mph. Can anyone help me?
grabon77 is offline   Reply With Quote
Old 03-22-2008, 07:32 PM   #2
mod-o-tator
i would check for vacum leaks, spark and fuel pressure to start out with. do you have a SES light on?
member map add yourself
alldatadiy
Old 03-23-2008, 02:03 PM   #3
didnt 79 still have the paper filter in the carb? I'd start there, especially if you have to crank it a bit to restart.
Old 03-23-2008, 03:36 PM   #4
there is no ses light on. It is an after market carb but i don't have to crank it to restart, it fires right back up. Someone else suggested that it might be the weighted springs under the distributor? I will check vacuum leaks and fuel pressure to start with. Thank you for the replys, any other ideas would be appreciated.
Old 03-23-2008, 05:36 PM   #5
Banned
sounds like its arcing under the dist cap. i would check your rotor. if its no that then check your fuel pump. if you dont have an electric fuel pump i would get one
Old 03-24-2008, 01:52 AM   #6
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
if you have dual tanks your switching valve is bad
jimbo543 is offline   Reply With Quote
Alpine V-Power Mono Power Amplifier 400 Watts model MRP-M450 with a Type E 12inch Hig Draggindime8 Truck Classifieds 0 02-20-2008 11:55 AM
Need more power!! Itstali25 Chevy Truck Forum 2 09-28-2005 05:44 PM
Pickup Crash Causes Power Outage Truck Hits Power Pole Near I-70 Car Dealer (The Kansas City Channel) trucknews Truck News (headlines) 0 03-16-2005 09:30 PM
Canada's film industry seems like an aging, fading star (International Herald Tribune) trucknews Truck News (headlines) 0 12-26-2004 05:30 PM
‘NYPD Blue' fading to black after 12 years (Kansas City Star) trucknews Truck News (headlines) 0 12-13-2004 01:30 AM
