Old 03-23-2008, 08:50 PM   #1
tattedchevychik is on a distinguished road
Question Please help I am newbie Transmission Problem
I have a 1994 Chevy 1500K with a 383 in it and a 4l60e transmission. It will not shift into 3rd gear just bought the truck 3 months ago . And today it decides to give me this problem . Yeah Happy Easter to me right lol. I have 1st gear , 2nd gear, and reverse but nothing after 2nd. Please any suggestions will be appreciated greatly!!!!
tattedchevychik is offline   Reply With Quote
Old 03-23-2008, 11:18 PM   #2
dawright_1988's Avatar
dawright_1988 will become famous soon enoughdawright_1988 will become famous soon enough
I've got some bad news for you. Please sit down before reading any further... You need a new transmission. Normally I wouldn't be so sure or quick to judge, but these trucks are notorious for dropping their third gear. It just gets stripped out pure and simple. I should know... it happened to me around 135k and my grandfather around 90k. Mine is a 96 and his is a 92. It costs about 1400 to have them professionally rebuilt. If you can do it yourself, or buy a new trans and just bolt it in... more power to ya. You might save a few hundred. Sorry for the bad news.
"You can polish a piece of junk all you want, but in the end, all you're left with is shiny junk."
dawright_1988 is offline   Reply With Quote
Old 03-24-2008, 10:41 PM   #3
Unhappy Thanks
Thank you for your input I appreciate it!!
Old 03-24-2008, 11:02 PM   #4
Slow down a minute. Does 4th gear work? This thing wont shift past second gear right?
It appears to me that the most logical cause would be a sticking 2-3 shift valve. Look at a hydraulic schematic, you will see that the 2-3 shift valve controls not only 3rd gear but also 4th. I would also look hard at the 3rd accumulator check valve and the orfice in the servo bore to be sure they are working correctly and that they are actually there.
Other common problems could be the capsule, or shuttle valve. The ball could be stuck and preventing the transmission from shifting,
I am not discrediting any other advice, it has just been my experience that many of these transmissions are taken apart and re-built before they are required.
These are pretty tough transmissions, and can last for a very long time.
Old 03-25-2008, 12:40 AM   #5
Thanks
I am not sure if we have 4th gear cause it won't shift passed 2nd.
Old 03-25-2008, 06:12 AM   #6
03chevy's Avatar
i have a question for you. did you change all the fluids after you bought it. if i buy anything used the first thing i do is change all fluids motor, trans, diff. , fuel filter i mean everything. just because you don't know when the last time they have been changed.
Old 03-25-2008, 01:19 PM   #7
Yes Everything has been changed !
Old 03-25-2008, 01:34 PM   #8
Does it try to shift into 3rd gear, and there is nothing there? Or does it just not shift at all?
If no shift at all, you could have a bad signal, or broken lead, a bad solenoid, or a bad valve (stuck ball) this does not mean that the trans has gone south yet.
3rd clutches could have taken a dump, but is not that likely yet. Couple of seals, or some other small items could very well be causing your problem.
I do not want to fill you with false hope, as this thing could be cooked, but in the same regard, I do not want you to shell out big dough if you dont have to. WOuld be nice to spend 20 bucks on a solenoid, and replace / clean a valve or two to get you rolling again.
Old 03-25-2008, 07:41 PM   #9
It doesn't try to shift into 3rd at all the motor just runs wide open. I got ahold of the guy we brought the truck from the trans was just rebuilt 20,000 miles ago at Scotts transmission in Lebanon PA ! So I am hoping it is something simple I don't think the trans would take a dump that fast. Well I am hoping
Old 03-25-2008, 07:51 PM   #10
As I mentioned before, this is an occurance that often gets overlooked, and transmissions get replaced as a result of it.
This shop should be able to determine if the trans is getting a shift command or not. If it is not, then the problem is simple to isolate, if it is rrecieving a signal, then the problem is again easy to isolate, since we know that the problem is inside of the transmission.
I am still leaning towards a low dollar solenoid, seal, or valve.
90 150 engine or transmission problem liftedtrucks4me Ford Truck Forum 1 01-31-2008 06:59 PM
Transmission problem shorton5 Dodge Truck Forum 26 09-06-2007 01:27 AM
Newbie here with a problem steve05ram360 Chevy Truck Forum 5 07-04-2007 12:17 AM
transmission problem 83 gmc joeydeherrera54 GMC Truck Forum 2 03-20-2007 09:27 PM
Transmission Problem z71chevy1996 Chevy Truck Forum 0 12-23-2006 04:05 PM
