Old 03-26-2008, 09:47 AM   #1
greasemonkey's Avatar
greasemonkey is just really nicegreasemonkey is just really nicegreasemonkey is just really nicegreasemonkey is just really nice
Question SAS on a S-10 Blazer
Im wondering if a Dana 30 solid axle out of a jeep wrangler will fit under the front of my 1992 S-10 Blazer. The pumpkin is under the drivers side on the jeep. I know i will have to weld up some spring hangers, but other than that would it be a bolt in deal, or am I getting in over my head?
greasemonkey is offline   Reply With Quote
Old 03-26-2008, 10:22 AM   #2
When you use the term "bolt in deal", you are underestimating the job at hand. The dana 30 front axle does have the driver side drop like you need, but this is where it stops.
You will need to determine which style suspension you are going to use, and which type of link system you intend to build. Know that designing a multi link system is a very difficult task, and not for the first timer.
Axle location, pinion angles during suspension cycles, roll centers, caster changes, are all factors when designing a suspension. Get on or more wrong, and the vehicle will not drive on the highway.
This is what you are trying to do, and let me tell you, this is quite a bit of work. Great modification, but man its quite time consuming.
Old 03-26-2008, 10:50 AM   #3
junior3382's Avatar
75K30, is that a project you worked on, or a random pic from the net? I agree, this is very leabor instnesive, and not for someone with limited knowledge, but boy does that look pi$$ed off, don't ya think! LOL. You know 75, it is a royal shame you and I do not live closer to eachother, I would love to spend a week shadowing you in a garage and perhaps building a project like this....LOL.
Old 03-26-2008, 11:16 AM   #4
I was planning on using leaf springs like the stock wrangler setup. when I said bolt in deal, I mean will I need a custom front driveshaft, or different transfer case.
Tractors are like watermelon, you keep the red and throw away the green."
Old 03-26-2008, 11:41 AM   #5
Junior:
I hit you back in a PM.
greasemonkey:
There will be nothing that will be a bolt on. If you use leaf springs, you will have to make some spring hangers to attach the springs to the frame. This is the easiest suspension design, but has some critical points as well. You will want to make sure you have a rear swing shackle, not a front swing like a Jeep. So you will have a fixed front hanger and a pivot at the rear. The frames are different widths so you will also have to fabricate some spring pads to attach the axle to the springs. Caster angle is very, very important here. Too much, or too little and the steering will be like the worst shopping cart you have ever pushed, or the opposite, the steering will be so slow, that the turning radius will be terrible, and the truck will fell slow to respond on the highway. This will aslo affect the front driveshaft pinion angle.
You will have to modify the exhaust, and yo will have to make modifications to the front driveshaft. You will have to be able to make up your own steering, since this is not a factory application everything will be custom. The relationship between the box, and the pass side knuckle is not a factory dimension, so you will have to fab something up.
You existing t-case will work, since it does not even know what is at the other end of the driveshaft. That will be the easy part.
Getting an axle located up front is an interesting deal.
If you use a Jeep axle, you will also have to eliminate the factory axle disconnect and add some locking hubs, or try to use the factory disconnect from the S-series truck, and try to make it operate the Jeep disconnect. This will prove to be an unreliable set-up, and eliminating this will be the best thing to do.
I like the idea od the SAS, and appreciate what you want to do. I personally feel that 4wd vehicles should all have solid front axles, and I modify mine this way, but I do want you to understand how much is involved.
This is a not turn back modification, meaning that once you start cutting the a-arms off, you will not be going back.
Old 03-26-2008, 03:38 PM   #6
Thanks for the info, Im thinking this will be an ongoing project for the summer. I plan on putting a standard s-10 pickup cab on the Blazer frame and making a custom tube bed for the rear. Maybe even some 3/4 ton axles further down the line.
Old 03-26-2008, 03:47 PM   #7
junior3382's Avatar
Definitely sounds like it will be quite a rig! Be sure to take project pics and post back.
Old 03-26-2008, 04:06 PM   #8
I will. I dont want to rush the blazer, I want it to be as strong and dependable as possible. Its going to be a hard core trail rig hopefully. Im not sure if my 4.3 is going to handle the strain Im going to put on it. my ranger is going to be my daily driver once I fix the tranny and replace the quarter window.
Old 03-26-2008, 05:00 PM   #9
junior3382's Avatar
Do not underestimate the 4.3l. With the right tuning and correct gearing, that engine will prove to you that it is the little engine that could....
Old 03-27-2008, 11:36 AM   #10
Banned
i agrea abou the engine that could. i just bought a 2000 jimmy with the 4.3. who ever owned this truck before hand definitly didnt take care of it. i just bearly got it home. i knew from the dealership i was replacing the motor. i bought the truck for 1900 with a brandnew motor in the back of the truck so i had an idea what i was getting myself into. but anyway i got it home and just out of curiousity pulled the oil plug. i have never seen such a nasty sight. the oil didnt come out it just sat there at the end of the hole not moving an inch. the provious owner drove the truck 103,487 miles without ever doing a thing to it. it is still inthe shop after 3 weeks tryin to come back to life. i should have it back by monday but its costin me alot
89 blazer luckyone Chevy Truck Forum 3 07-28-2007 07:05 PM
k5 blazer chevygirl91 Chevy Truck Forum 1 07-26-2007 09:43 PM
94 Blazer 4.3 Hayden Chevy Truck Forum 5 11-14-2006 07:43 PM
4x4 s-10 blazer mudseeker Truck Classifieds 0 08-27-2006 08:58 PM
A/C help - 98 Blazer 4.3L corey Chevy Truck Forum 4 08-23-2006 11:05 AM
