Old 03-30-2008, 12:07 PM   #1
david 87's Avatar
david 87 is on a distinguished road
Trans good or bad
i have a 87 chevy with a 700R4 it needs rebuilt. rebuild it or put a 400 or 350 in its place
david 87 is offline   Reply With Quote
Old 03-30-2008, 12:39 PM   #2
Chevy_Finatic79's Avatar
First an 87 should be TBI if it is you want to stick with the 700R4 for a couple reasons. a 350 is shorter than the 700R4 and the 400 so you would need a longer driveshaft. and the 350 dosent have overdrive which ive been told the TBI systems need in order to "save" gas MPG on the highway. and you have to buy an aftermarket Vehicle Speed Sensor to talk with the ECM
The 400 has a bigger output shaft which would mean at least a new yoke and or a different driveshaft. it too is a 3 speed no overdrive. but the kickdown can be controlled by the ECM and i think you need an aftermarket speed sensor for that one too.
Thats all I got
Old 03-30-2008, 04:19 PM   #3
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
700R4 is a good transmission and can be made stronger if you need . Up grades are available when rebuilding such as beast sun shell steel pistons instead of aluminum shift kits etcetera .. But good luck which ever way you go
PAPA BEAR is offline   Reply With Quote
1979 C10 trans NC4W Chevy Truck Forum 1 12-30-2006 07:42 PM
auto trans Q's mtfit Dodge Truck Forum 1 12-21-2006 09:06 PM
trans help metalbender Chevy Truck Forum 0 12-09-2006 09:10 AM
trans out nate02 Nissan Truck Forum 1 05-17-2006 10:15 PM
Trans & t Case elkzzilla Chevy Truck Forum 1 12-04-2004 09:25 PM
