| Silverado fuel pump voltage Hello everyone I have a 2001 Silverado I am getting very good at changing out fuel pumps in past year for various reasons we wont get into. My question is does anyone know for sure what voltage I should get at fuel pump connection when I turn key on. Reading different numbers on various sites. I get 5 volts. So is supposed to be 5 or 12 ? |
| 5 volts is for the fuel level sending unit, 12 volts should be for the pump itself, you won`t get a constant 12 volts either, its only on for a few seconds, you need someone to run the key while you check for voltage to pump |
| If you are having fuel pump replacement problems, have read a number of folks with that problem. Use top quality fuel pumps, from gm, cost more in front end but last longer. |
| 02 sensor bank 2 low voltage 99 silverado 5.3 | mxkevin231 | Chevy Truck Forum | 1 | 03-21-2008 06:54 PM |
| 96 k1500 silverado fuel pump | maddog | Chevy Truck Forum | 6 | 02-23-2008 10:04 PM |
| 99 silverado fuel pump | rockitman | Chevy Truck Forum | 11 | 12-07-2007 04:39 PM |
| 94 Chevy K1500 Fuel Pump Voltage | tdyer | Chevy Truck Forum | 2 | 10-15-2007 10:44 AM |
| 85 silverado fuel pump mystery | mntman | Chevy Truck Forum | 2 | 01-19-2006 07:35 AM |
