| My truck is a 2003 silverado 3500 w/ duramax. I jumped into it to get to work, looked at the fuel gauge. Gauge registered no gas with the low fuel light on. I thought someone had siphoned my 50 gallons of diesel out. Limped to the gas station to pump in another $150. in fuel. Low and behold I pumped only 20 gallons in. Gas gauge defective. No problem, I'll just set the trip meter. I drove 361 miles and ran out of fuel. I usually get 550 miles. Thought, what crappy mpg I got! Again, I limped to the gas station and filled the front tank and continued to the back tank. To my suprise, the back tank was full. So, there must be a solenoid switch or valve that isn't working as well. Anyone have any idea's? |
| Welcome to the club your going to meet a lot of nice people here. Check to see if maybe there is recall I wish I could help you more. GMC |
| | #3 | |
| Junior Member Join Date: Apr 2008 Location: texas
| Welcome to the forum jsl. Not run into this myself, but this was/is a noticed problem with that run of trucks, apparently gas or diesel types 2001-05. Gauge reads empty with fuel in tank, might have code P1172 and/or P2636. Aux (rear) tank balance line is in same T connection on main tank vent line as aux tank vent line. Fuel is pumped from aux to main via the balance line. Fuel is then sucked back into the aux via the vent line rather than going to the main. PCM doesn't see transfer between tanks and shuts off aux pump. Gauge goes to zero. That explaination made sense to me. "Recommend" to avoid this by shutting truck off while fueling and leave the key in OFF (that's the law BTW) Seems the suggested fix was to relocated the aux balance line from the T for the main (old location gets capped) to a new T halfway up main tank filler neck on the main's vent hose. Seems a little buggy to me, but that was how I understood it. |
| I took my 2003 chevy 2500 6.0 liter in to get the pc re flashed and the guy at the dealership told me that chevy had a recall on the dash clusters ... |
| Full Member Join Date: Sep 2008
| so, they need to clean the wiper motor or those wiper arms or just replace them? That can cause you to spend lots on fuel. Last edited by mudseeker; 10-24-2008 at 04:05 AM. Reason: remove link |
| chankee, you have got me more confused on this one. did you mean to post this to another thread?? |
| lol i do belive he messed up... kind of funny if you ask me... i didnt know what was goin on for a sec |
| Full Member Join Date: Oct 2008 Location: Florida
| I have an 02 silverado but its a gas motor and am just recently having the same problem. I had the same thought, **** someone siphoned my gas but when i tried to fill it back up it only took $15... common defect with the gage Ive heard this from so many chevy owners, dont know how to correct it. it you figure it out let me know! |
| it said his friend at the dealer called this broken part a wiper to the senor and it is in the fuel cell to get to the sensor in the fuel cell they had to remove the truck bed. |
| fuel gauge | gummie | Chevy Truck Forum | 7 | 01-15-2008 04:17 PM |
| Problem with my 2003 chevy silverado oil pressure gauge | a1badboy | Chevy Truck Forum | 1 | 06-08-2007 11:05 AM |
| 1982 Chevrolet Silverado fuel gauge | N44252 | Chevy Truck Forum | 5 | 05-07-2007 07:59 AM |
| 1981 C-10 Fuel Gauge problem | DaleP1981 | Chevy Truck Forum | 2 | 10-20-2006 05:53 PM |
| 2003 silverado problem | derspinna | Chevy Truck Forum | 0 | 03-02-2006 03:11 PM |
