| Full Member Join Date: Mar 2008
| fuel issues ?? I think I might have some fuel issues. I have 12 psi of fuel pressure, the plugs show that there is a lean condition across the board. I replaced the intake gasket and the tbi gasket because of a low vac reading ( I am asuming from to much cam) the truck runs great finaly will out run a vortec v6 0-55mph (first run was before replacing MAP, egr, o2, plugs&wires, Cap&rotor, IAC, and rebuilt the TBI. my main problem is the stumbling and stalling as well as when i test the fuel pressure it dose not hold any pressure. I had to have the motor running inorder to get a reading. this is on a 92 2500 350 auto. cam specs unknown 15in. hg. vac reading warm in Netural. thanks Justin |
| did you rebuild the motor or something? and did you you put a much bigger cam in it to try and gain extra hp? if so then you need more fuel. a bigger cam requires more fuel and more spark and retard timing.
| doesn't that fuel system bleed itself down by design with eng off? That's what I understood. |
| Senior Member Join Date: Jan 2008 Location: L-burg KY
| i though that too
__________________ 1998 Jeep Grand Cherokee Limited 5.2 Full time 4WD NP249 |
| yes it does. but if you are running lean and low vac. did you change the injectors with the bigger cam?? and add a vac canister to help with the vac system. so what i'm saying is you can not change one thing and get it to work proper with out changing anything else
| Fuel pump, fuel tank, filler neck, filter... | lassy | GMC Truck Forum | 6 | 04-11-2007 06:48 AM |
| '99 Suburban Fuel System Issues | jesusdrivesagmc | GMC Truck Forum | 14 | 02-27-2007 11:05 AM |
| Anyone With Fuel Issues Run A Search | Chevy808 | GMC Truck Forum | 2 | 01-11-2007 06:46 PM |
| abs issues | HVY84CHVY | GMC Truck Forum | 5 | 01-02-2007 10:24 AM |
| A C issues | mikerike | Chevy Truck Forum | 9 | 07-24-2006 06:46 AM |
