Old 04-10-2008, 11:24 AM   #1
Chevy_Finatic79's Avatar
90' burban electrical problem
due to a run in with the law I havent had a drivers licence for the last year and beleive it or not I havent drove any of my 3 vehicles or motorcycle.
about once a month I start the "rides" and let them Idle for about ten mins or so, well when I went to turn off my suburban and disconnect the Batt I shut the door and went to the hood when I noticed the dome light was still on with the door closed?? I played with the "pin switch" in the door jam notihng I checked the headlight switch to see if somehow the courtesy lamps setting was on and it wasnt. I had to end up pulling a fuse to shut the lights off?????
Normally I wouldnt post something like this because there would of been a direct cause related problem but my burban has done nothing but sit the past year no wiring done, no work what so ever has been done except I changed the bench seat to buckets and the only wire is the fasten seatbelt wire.
IDK WTF happened from just sitting has anyone else had a similar problem?
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 04-10-2008, 12:57 PM   #2
03chevy's Avatar
it has not done this before? like most of the new ones now have a delay after the doors are closed 30sec the doom light stays one then goes off
Old 04-10-2008, 04:07 PM   #3
Banned
there is a hood pin that i beleive may turn on your inside ligh when the hood is open
Old 04-10-2008, 04:13 PM   #4
nope mine dont have the relay or the hood pin, remember the 90 burban is the 80's -87 body style carried over not much "new" stuff on it its perrty old school setup still
Old 04-10-2008, 06:40 PM   #5
crabtruck's Avatar
On the assumption you did not turn on a switch on the light itself, pull the door switch. They do age and this is almost 30 years old. If the switch is not internally sticking, the wire may have dropped off, grounding elsewhere. If it's not that door, the same could be true at the others whether you opened them or not. Could also be shorting to ground at light fixture(s).
Old 04-11-2008, 09:18 AM   #6
Nold Dog is on a distinguished road
My sister's '93 Suburban had exactly the same problem. If it sat for 4-5 days the battery was dead. One night she noticed that the courtesy lights were on while it was parked in the driveway. Turned out to be a bad pin switch on the rear lift door.
Don
Don
1968 Chevy El Camino
1991 Chevy C3500 Dually
Nold Dog is offline   Reply With Quote
Old 04-11-2008, 09:47 AM   #7
yea I havent actually pulled the door switch pins out yet but I'm going to do it very soon and see if the is my problem. when I did pull the fuse I still had a parasitic draw I wonder if that was the memory on my stereo or something else?
Old 04-17-2008, 09:46 AM   #8
so yesterday I decided to dig in and see what the problem was and when I put the battery in the dome lights were not on??? I took all of the door pins out and cleaned the contacts with a wire brush then I put dielectric grease and reinstalled and tested them they all and they worked fine, so I went to take the rear Double door pin out and this one was totally different than the others. when I opened the door the lights didn't come on but when I played with the door switch the lights came on, so I knew it was bad.
I haven't replaced it yet just removed it and that cured my problem "stupid little switch"
Old 04-17-2008, 03:17 PM   #9
crabtruck's Avatar
So many electrical problems are back door ...
glad you found it.
Old 04-17-2008, 08:18 PM   #10
Banned
does it have the barn style rear doors. if so do you know where to find cheap replacements. all i have found for my buddys is rusted the same as his. he needs them to be totally new like inside and out. he has rot on the skin and interior
93 S-10 electrical problem lite39 Chevy Truck Forum 2 08-08-2008 07:05 AM
93 electrical problem lite39 Chevy Truck Forum 5 05-07-2008 08:02 PM
95 s-10 electrical problem joshuapa Chevy Truck Forum 4 03-31-2008 07:27 PM
need help bad PLEASE!!! 97 nissan electrical problem john0deere7 Nissan Truck Forum 1 12-17-2007 04:00 AM
electrical problem hjsherrod Introductions 1 01-23-2007 02:46 PM
