Old 04-13-2008, 08:49 PM   #1
forgey1973 is on a distinguished road
signal problems
i have replaced the fuse the flasher and check for ground problems emergencey flashers work except the front passenger side and still no turn signals.... any ideas of what to look for in my 97 silverado
forgey1973 is offline   Reply With Quote
Old 04-14-2008, 12:00 AM   #2
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Welcome to the forum forgey1973.
In a nut shell, you have two fuses, haz/turn switch, bulbs and wiring.
Two steps will likely fix you up.
Step one is replace RtFront bulb if only one is problem,
or check ground connections if both sides of corner is a problem.
Step two is check Turn-B/U fuse #16 15A, not just Stop/Haz #1 15A in IP fuse block.
If good then key out, remove flasher, enable hazards. Use volt meter or test light
to see which pin of flasher socket is hot. Only one will be(Grey).
With Hazards off, key back on, set turn signal (either side). Check for hot on a different pin hole(LtBlue).
If none, switch, or wires from it to flasher or turn fuse the problem.
If ok so far, key off, install flasher, key on, set turn signal. Look for hot on output of flasher (Purple).
If this step is akward, skip for now since low probability.
You can check output of turn signal on DkBlue,Yellow or DkGreen depending on left or right.
These wires are same with flasher, so a total absense of hots with turns points back to switch as problem
Old 04-14-2008, 06:49 PM   #3
thank you for the info i truly appreciate it i will follow your steps thank you again
Nutty turn-signal dawright_1988 Chevy Truck Forum 20 12-01-2008 07:20 PM
Turn signal problem please help lemoncoke GMC Truck Forum 5 02-07-2008 06:02 PM
Signal Mirrors leanne Ford Truck Forum 4 02-20-2007 01:47 PM
turn signal switch 79ford4x4 Ford Truck Forum 2 09-30-2006 07:26 AM
1993 Ford ranger turn signal problems 72'CaminoKid Ford Truck Forum 1 08-05-2005 08:22 AM
