| Full Member Join Date: Dec 2007
| 93 chevy fuel pump & tank drain question where is the fuel pump located on a 93, 350cid engine? I need to gas tank and wonder best way to do it, can I use the fuel pump on the vehicle or what? Can't run tube into fill location as it stops with some kind of obstruction in tube, ideas??? |
| what kind of "tube" are you using. a nice 5 to 7ft piece of 5/16 or 3/8 rubber fuel line should fit in the filler tube, I use an old piece of air compressor hose myself and it goes in every gas tank I've sucked gas out of. are you familiar with running a plumbers "snake" try twisting the hose until it goes in the hole at the bottom of the filler tube. all fuel pumps on 87' and later GM full size trucks are mounted in the gas tank
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 5.7 Liter/THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| or you and a friend with a floor jack and a piece of wood undo the straps lower it a little to get to the hoses and wire to undo them then drop it all the way down.
| can I jump the relay on the fuel pump and use it to pump fuel out? where is relay and what wires or connections do I jump??? thanks. |
| Senior Member Join Date: Mar 2008 Location: levittown pa
| just look for the wires that run into the fuel tank all you need is the power and then you can run it all day. but it will take for ever though. |
| I decided to try and siphon gas out...bought 6 feet of hose and it worked great, thanks all. |
| 86 Chevy C10 Dual Fuel Tank issue | Dragonfly | Chevy Truck Forum | 11 | 10-27-2008 01:48 PM |
| 87 chevy dual fuel tank help | rugy04 | Chevy Truck Forum | 7 | 01-27-2008 01:06 PM |
| Fuel pump, fuel tank, filler neck, filter... | lassy | GMC Truck Forum | 6 | 04-11-2007 06:48 AM |
| The "lift bed" Procedure for R&R tank mounted fuel pump? | Shox | Chevy Truck Forum | 4 | 02-16-2007 12:01 PM |
| fuel pump question | rrowe | Chevy Truck Forum | 3 | 05-19-2006 06:57 AM |
