Results 1 to 3 of 3
Thread: 2.73 rear end gear ratio good or bad
    Senior Member Chevy_Finatic79's Avatar
    Mar 2008
    Lincoln NE
    I know everyone wants 3.73 or 4.10 gear ratios for hi perfomance cars/trucks but how does a 2.73 compare the only thing I can think of is that is spins lower hiway rpms and is fuel friendly. I could be wrong rear ends arent my thing
    what is the most Ideal gear ratio for a full size 85 1/2 ton chevy truck?
    I dont want a 4.10 becuase I will be on the hiway quite a bit and hi rpms drive me nuts I hate whining. I'd like to get in the 3.'s at the very least though 3.40's or better.
    I know there is a math equation to find gear ratio and thats all great on paper I want real life hands on feedback tho. so any one out there that has swaped out a bunch of rear ends to find that Ideal gear ratio I need your opinions and feedback.
    Thanks Slicc
    85' Chevy C-10 Longbox (Rat)
    TBI 327 Cu.In./THM350
    90' Chevy Suburban 4x4
    TBI 350 Cu.In./700R4
    Jul 2006
    The ratio charts can be your friend. They will provide you with the proper ratio to keep you engine at the proper rpm.
    While we have had several discussions with regards to gear ratios, and I will bring back up a few key points.
    Far too many folks are concerned about highway rpm's and they believe that the lower the rpm's the better. While this is fairly true for most cases, many fail to realize that vehicles have to still produce a given amount of torque to maintain foward motion. If the ratio is too high (numerically lower) like under the 3.0 range, and the taller tires of a truck is not compensated for, the truck will be foreced to work harder to maintain the same speed, and would be counter productive. Chances are, it will take more throttle to just slightly accelerate, and if too much throttle is required, the transmission will downshift, taking the engine rpms way higher than it would if the truck was equiped with a better gear.
    As long as we are talking about acceleration, we should also discuss how often this vehicle has to start from a dead stop. This ratio wil make it diffficult to maintain speed, it will also make it more difficult to roll from a stop. All of this will take a toll on mileage averages. This is where a ratio that provides a mechanical advantage is far superior.
    The weight, and the tire diameter of a full size truck makes me really have to suggest the right ratio for a given application, and a ratio that is suited for a lighter car, with shorter tires may not be the best for this truck.
    Tire size is an important factor that has been left out here.
    Mar 2007
    I've always been told that for the best fuel mileage keep the engine rpm where it makes the most vacuum. But, nobody ever clarifys manifold or port vacuum. it makes some sense, but still somewhat unclear.
    1962 Scout 80 parts I guess
    1966 Scout 800 resto job
    1996 P30, 6.5 NA Mac Mobile
    whole lot of buicks
  1. Likely gear ratio?
    By 436'd skylark in forum Chevy Truck Forum
    Last Post: 12-19-2007, 03:17 PM
  2. Changing Gear Ratio in a One Ton
    By Super Step in forum GMC Truck Forum
    Last Post: 09-21-2007, 02:53 PM
  3. Gear Ratio??? What If????
    By Maverick in forum Chevy Truck Forum
    Last Post: 07-27-2006, 08:58 PM
  4. How do I tell what gear ratio I have in my truck?
    By big_bad_jer05 in forum Dodge Truck Forum
    Last Post: 07-10-2005, 06:40 AM
  5. Gear Ratio???
    By Billy2001Z71 in forum Chevy Truck Forum
    Last Post: 06-19-2005, 01:27 PM
