Old 04-18-2008, 01:02 PM   #1
Finkish is on a distinguished road
98 chevy z-71 transmission problems
I have a 98 chevy z-71 with 180k miles on what i believe is the original xmsn. Today, while passing a slower car, the xmsn slipped and the engine revved. It continued to pull but shifts like it is slipping (revs high even at moderate throttle position). It does not engage in reverse at all. What does this sound like to you guys?
Finkish is offline   Reply With Quote
Old 04-18-2008, 01:25 PM   #2
03chevy's Avatar
when have you changed the fluid? or could be a solenoid has gone bad
Old 04-18-2008, 02:01 PM   #3
It was changed when I bought it. 166k
Old 04-18-2008, 03:47 PM   #4
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
It sounds from the sounds of it like you have broken your sunshell. When this happens you will lose reverse and also 2nd and 4th. So you will skip and and go 1st to 3rd.
If you need a transmission these guys Carolina Performance Transmissions - 4L60E Transmission Specialist are great and can really make one last for heavy duty and towing abuse. Even stock stuff too.
PAPA BEAR is offline   Reply With Quote
Old 04-19-2008, 02:26 AM   #5
I like what Papa Bear has to say. The sunshell will cause these symptoms.
You may also consider that with the miles it is entirely possible that the "lo-reverse" clutches are just plain wore out, or there could be a fluid leak in the reverse apply circuit. Some of the symptoms could also be caused by a faulty speed sensor, but would not explain the lack of reverse.
Broken hardpart, or simply a wore out trans might be the case here. You wil have to open her up. Drop the pan and take a look at what is sitting in the bottom. Probably the best troubleshooting available. This should tell you what you want to know.
Old 04-19-2008, 07:53 AM   #6
Thanks folks.
What year Pickup Transmission will bolt up in my 68 Chevy? wcedgar Chevy Truck Forum 8 04-01-2008 07:04 PM
Chevy 3/4 ton Transmission shift problem OD issue fbhart@wk.net Chevy Truck Forum 2 09-23-2007 07:00 PM
88 Chevy Cheyenne Needs Transmission BigBahama Chevy Truck Forum 3 10-05-2006 01:45 AM
Chevy 4x4 Transmission question lonnie Chevy Truck Forum 1 12-25-2005 10:14 PM
allison transmission problems? Sandy C GMC Truck Forum 2 03-17-2005 06:45 AM
