Old 04-18-2008, 03:39 PM   #1
marcus is on a distinguished road
Fuel Gauge Goin Haywire
Hello,i Noticed The Last Year Or So That My Fuel Gauge Works When It Wants To.most Of The Time It Reads Empty,even If The Tank Is Full,then Will Spike To The Correct Level.is This A Fuel Sender Unit?is It In The Fuel Tank?how Much To Fix? Thanks Marc
marcus is offline   Reply With Quote
Old 04-18-2008, 03:46 PM   #2
Chevy_Finatic79's Avatar
it is possible that the wire going to the sending unit has rubbed on the frame and broke,shorted or got corrosion in the wire creating resistance that gives it a mind of it's own. I would check the wire first
then bite the bullet and drop the tank because unfortunately for you the sending unit is part of the fuel pump assembly which is located inside the tank depending on what year it is.
might be a good time to replace the fuel pump screen filter and the pump depending on what year it is while you have the tank dropped if you have to go that route
85' Chevy C-10 Longbox (Rat)
TBI 327 Cu.In./THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 04-18-2008, 11:10 PM   #3
This the 1999 silverado ?
Old 04-19-2008, 09:38 AM   #4
thats correct.is that wire your talkin be acsessed fairly easy?where is it?thanks marc
Old 04-19-2008, 11:27 AM   #5
zazlo is on a distinguished road
You might try adding a can of fuel injector cleaner to the tank.Ive cleaned high resistance build up on the sending unit this way before.Hope you dont use shell fuel.I use BG44k injector cleaner,it real works great.If you cant find it try the chevron techroleen additive.Its the same product just not as concentrated according to the BG rep.Maybee 2 bottles to a full tank of fuel.good luck
zazlo is offline   Reply With Quote
Old 04-19-2008, 12:01 PM   #6
the wire I speak of is usually on the drivers side frame rail if it has a saddle tank but it can also be on the passenger side as well. On my truck which is older the sending unit wire is pink and it runs in the same wire loom going to the tail lights.
if you get under the truck and start at the tank look for a black plastic wire loom follow that wire loom from the tank to the firewall and see if there is any signs of damage to it like a pinch or rubbing on the frame. if you can without dropping the tank see if the pink wire has continuity from the tank to the firewall.
Old 04-19-2008, 04:01 PM   #7
good advice,i will follow that.thanks marc
Fuel Gauge and Oil Pressure Gauge problems landonh GMC Truck Forum 12 04-23-2008 10:26 PM
fuel gauge gummie Chevy Truck Forum 7 01-15-2008 03:17 PM
fuel gauge? 396chevy Chevy Truck Forum 5 01-15-2008 10:04 AM
gas gauge goin crazy duckkiller0010 Chevy Truck Forum 4 07-17-2007 10:25 AM
Fuel Gauge probs robbber Chevy Truck Forum 3 07-28-2006 09:40 PM
