| Full Member Join Date: Apr 2008
| I have at least blown head gasket in my 86 C30/350 motorhome with 10K miles on rebuilt engine. It looks pretty tough to RnR head with engine in place. Should I bite the bullet and pull engine to do this job? I'm not an ace but have good help and air tools available. Related issue: With engine running I had a LOT of oil vapor from hose to aircleaner to the point where oil was leaking out of cannister and dripping on engine. I then found that the smog pump belt was way loose. Tightening the belt made the engine run better immediately. Does that make sense? A mechanic opined that the oil vapor was blowby and thought the engine was a goner. I'm hoping the smog pump not working was the cause of the extreme vapor issue, and that all I have is a blown head gasket. I drove engine about 100 miles with gradually decreasing power. Found water in two plugs (so far) and steam coming from one exhaust pipe. But rig still starts and runs reasonably well with 2 new plugs, I don't think it's a goner yet. Found brown residue in radiator overflow tank but no evidence of water in oil. Thoughts? |
| Full Member Join Date: Apr 2008 Location: vancouver bc
| sounds like the head gskt or gskts are aproblem.you can help isolate this by removing the valve covers.turning the engine over by hand untill the suspect cylinder is at TDC [both valves closed] and introducing shop air into the cylinder,a leak down test.[100-150 psi is fine] .The cooling system will either build pressure[with the rad cap on] or with the rad cap off you may see bubbles in the rad.Watch for a cracked head when you isolate which cylinder[you can have them pressure tested at any compitant machine shop]the excessive blow by may be steam caused by water in the oil.The leak down test will also show you if the rings are an issue by bowing excessive air out of the crankcase.Look at the plugs when you pull them out the bad cylinder will be very clean or show sighns of coolant.If the leak is bad enough you can pressureize the cooling system for 15-20 min ,crank the engine over with the starter [ignition syst disabled]and watch for which hole blows out coolant.The cooling syst will have to be flushed ,Ive found using dish washer soap works well.[it cant make bubbles].You may have to do this numerous times |
| Thanks. The longer I look at things I realize I can get the head off without removing the engine. |
| Buy new head bolts when putting the heads on this time. zazlo your the man good help. |
| Yes you can get the head out we used to do it on the van bus version. Chances are the head is cracked between the valves, So anything you do will be a patch on an old engine that was rebuilt. If the coach is in nice shape and you are going to pull the engine put a goodwrench in it, not a rebuild! that way everrything is new and current. |
| Thanks. I've been reluctant to start. Next week will tell the tale. |
| i agree with gmstrucks new head bolts old ones get streched and do not torch out right!!
| 2007 GMC Sierra Classic Crew Cab Head Rests Removal | TX900s | GMC Truck Forum | 1 | 08-02-2007 10:56 AM |
| gear removal | mazdaman | Mazda Truck Forum | 1 | 02-20-2007 05:20 PM |
| 99 ranger oil pan removal HELP lol | btooling | Ford Truck Forum | 0 | 01-18-2007 08:56 PM |
| C10 delux bed removal | 72'CaminoKid | Chevy Truck Forum | 5 | 12-05-2006 05:19 AM |
| S10 4x4 Torsion Bar Removal | matthews | Chevy Truck Forum | 1 | 08-02-2005 11:37 AM |
