| I Pulled This Code From My 99 4 Wheel Suburban 2500 Series 7.4l Abs Light Comes On When You Start To Move Co246 Ebcm Control Valve Circuit Does Anyone Know What This Means Thanks. |
| Welcome to the forum floydanddawn. Codes C0241-0254 get lumped together as EBCM: Control Valve Circuit but may actually be as simple as a dirty wheel sensor. Not sure if your truck is using the integrated hub (pricey to replace) or not. Don't think the '95s - '01s used them. Also, I thought C0241 was EBCM Control Valve Circuit code. There were some issues with trucks that triggered ABS at low speeds for dirty sensors also. If EBCM is detecting different wheel/truck speeds it will set an error. Suggest you check condition of front wheel sensors: corrosion, loose connections, etc. Possibly follow up with sensor testing. Make a basic visual check for loose or shorted connections through out system. There are related threads in forum, do a search. Good luck. |
| I will recheck code number left front whell drags behind by 1 mph then jumps up to speed with the other 2 after a couple of seconds if you check it while you're moving when i test drove it before I bought the suburban it didn't come on now it does it had been sittin for about a year because the rear was bad ( had to put new pinion and carrier bearings in it ) I will check sensors and yes it does have the integrated hub thanks. |
| code 42 | tjzz4 | Chevy Truck Forum | 4 | 04-08-2008 11:19 PM |
| 141 code | Robert78.5 | Chevy Truck Forum | 1 | 10-08-2007 11:44 AM |
| code 41 TPS help! | ray299 | Toyota Truck Forum | 3 | 12-01-2006 03:37 PM |
| Code 24 | MexToy93 | Chevy Truck Forum | 1 | 11-29-2006 08:52 AM |
| Code 54 | Slo 1 | Chevy Truck Forum | 3 | 11-24-2005 12:17 PM |
