| Advice needed on hesitation Truck is `92 K1500, 350TBI, 4sp auto, 121000mls. Truck had been sitting for about 5 weeks. As always it started easily and ran smooth. Drove it for about 10mls., stopped it and left it for about 30mins. and started on way home. Initially it was running good then after about 5mls. it started to hesitate really bad on acceleration. Back off and it ran good again. Got it home and checked plugs, all good color. Fitted a new fuel filter and drove it for about 20mls with no problem other than I noticed the idle speed dropped to about 300rpm, but very smooth. Left it for 30min switched off and then took it for another drive. Hesitation under acceleration from the word go. Any ideas. I`m thinking ign.coil but would appreciate any input. Forgot to say that there is no light on and only code stored is 12 Last edited by Case 7230; 04-21-2008 at 02:10 PM. Reason: add info |
| double check for a loose vacuum line/hose it sounds like a low vacuum problem
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 327 Cu.In./THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| Maybe TPS or bad gas try Lucas gas additive read directions first. |
| Thanks guys. I should have said in my original post that I put around 10gal. of new gas in it with a can of Cyclo Fuel Injector Cleaner. Made no dirrerence but I have not run it all thru the truck yet. I should have thought of Lucas, used it before in a diesel and did a great job. What gets me is that it only happens after the hot engine has been sitting for about half hour (getting hotter?). Runs at 150 degrees under normal running, well that is what the stock gauge says. I will certainly check the vacuum hoses and will report back if and when I solve the problem. Thanks again for your replies. |
| have you looked into these? 1Inspect Fuel Filter Clogged or dirty fuel filter 2Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 3Inspect Spark Plug Fouled, damaged or broken spark plug(s). 4Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 5Inspect Fuel Pump Improperly functioning fuel pump or circuits. 6Inspect Ignition Timing Incorrectly adjusted engine timing. 7Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit. 8Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. 9Inspect Air Cleaner Temperature Sensor Damaged or faulty air cleaner temperature sensor or air cleaner temperature sensor circuit. 10Inspect Accelerator Pump Diaphragm Damaged or faulty fuel injection accelerator pump diaphragm. 11Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor. 12Inspect Oxygen Sensor Damaged or faulty oxygen sensor or circuit. 13Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
| Thanks for reply. I`m thinking along the lines of No.2. May replace wires and see. |
| As promised I am posting back on fix for odd hesitation. Turned out that a new oxygen sensor solved the problem. |
| Miss or hesitation? | spacoli | Toyota Truck Forum | 4 | 01-07-2007 12:10 AM |
| 18" Rim advice needed | V-max | GMC Truck Forum | 3 | 11-13-2006 09:41 PM |
| 88 chevy hesitation | chevy_202 | Chevy Truck Forum | 2 | 11-10-2006 09:29 AM |
| 18x9" Rim advice needed | V-max | Introductions | 0 | 10-02-2006 02:35 AM |
| 2002 chevy hesitation | mario.adame | Introductions | 1 | 09-29-2006 07:49 AM |
