Old 04-21-2008, 10:19 PM   #1
jspeedo is on a distinguished road
rough idle
2002 Chevy express van. Will run good and all of the sudden when you start it again, it doesn't want to idle. It goes along time between these "episodes" but two weeks ago it did this and again tonight. This never set a code and it always clears up. Any ideas as to what the problem is?
jspeedo is offline   Reply With Quote
Old 04-22-2008, 06:52 AM   #2
03chevy's Avatar
you can start by checking this stuff.
1Inspect Idle Speed Control Actuator Damaged, loose, or faulty idle speed actuator
2Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit.
3Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
4Inspect Idle Stop Solenoid Damaged, loose, or faulty idle stop solenoid
5Inspect Idle Air Control Valve Damaged, loose, or faulty idle air control valve
7Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor.
8Inspect Air Filter Clogged or dirty air filter
9Inspect EGR Valve Clogged, dirty or improperly functioning or defective egr valve.
10Inspect Fuel Filter Clogged or dirty fuel filter
11Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
12Inspect MAP Sensor Improperly connected or faulty m.a.p. sensor.
13Inspect PCV Valve Plugged or damaged pcv valve.
14Inspect Point Set Burned, worn or incorrectly set ignition points.
15Inspect Spark Plug Fouled, damaged or broken spark plug(s).
16Inspect Fuel Pump Improperly functioning fuel pump or circuits.
rough idle jarhead2001 Chevy Truck Forum 21 03-22-2008 09:57 AM
Rough idle bevanlane GMC Truck Forum 11 01-22-2008 10:02 PM
Rough Idle utardcrew GMC Truck Forum 2 05-25-2006 11:54 PM
Rough idle utardcrew Introductions 2 05-25-2006 10:31 AM
rough idle bradturpin13 Nissan Truck Forum 2 05-09-2006 06:18 AM
