Old 04-23-2008, 05:13 AM   #1
rockitman's Avatar
rockitman is on a distinguished road
99 Silverado Steering Column Vibration
When making tight left or right turns (at a stop),there is a vibration in the steering colunm.Was told it could be a speed sensor.The vibration occurs only at that time.
rockitman is offline   Reply With Quote
Old 04-23-2008, 08:29 AM   #2
zazlo is on a distinguished road
Are you stuck in 4wd?,are the axle u-joints ok?,not sure if you have razepa style[they have a boot over them] or an open u-joint.Look for a torn boot or rust comming out of the axle u-joint caps where they join the u-joint
zazlo is offline   Reply With Quote
Old 04-23-2008, 01:03 PM   #3
stumpuller454's Avatar
need more info, is vehicle moving? are you braking while moving through a turn? if it vibrates when NOT moving it could be steering pump or box problem, let us know...
Old 04-23-2008, 04:36 PM   #4
rockitman's Avatar
silverado steering column vibration
When making a tight left or right turn (when stopped) there is a vibration in the steering column,also a "crunch".The "crucnh" is also there when l stop-driver side only.Took the truck in -they said something in the steering column-cant recall the name for it.
Old 04-23-2008, 07:23 PM   #5
hmmm, fixed now?
Old 04-23-2008, 07:35 PM   #6
rockitman's Avatar
silverado 99 steering column vibration
pickin up the truck tomorrrow.will update then
Old 04-24-2008, 04:00 PM   #7
rockitman's Avatar
99 Silverado Steering column vibration
The intermediate steering shaft was replaced.Vibration is gone.Slight "crunch" when stopped and turning wheel is still there.Maybe needs to be lubed? Could be normal l guess...
Old 06-11-2008, 07:44 PM   #8
rockitman's Avatar
Caliper was seizing.Pin was changed,Will check when the glue dries.
rattle in steering column ol_hounddog Chevy Truck Forum 14 03-06-2008 10:44 PM
Steering Column Housing TZR2 Chevy Truck Forum 4 05-05-2007 01:37 AM
steering column swap out help viperman Chevy Truck Forum 2 04-30-2007 03:15 PM
Changing a steering column NC4W Chevy Truck Forum 3 01-09-2007 08:11 AM
Steering column vibration in 92 4x4 mochester Toyota Truck Forum 3 05-20-2006 11:27 PM
