Old 04-25-2008, 02:28 PM   #1
bulachip is on a distinguished road
How much can I tow
I have an 89 4X4 1500 extended cab long bed. it has a towing package and the engine is quite strong. Supposed to have a 305 but the privious owner said he had a new motor installed and is not sure exactly what it is. I think it may be a 350 because it pulls quite strong and i am currently running 33in tires on this heavy truck. Anyway I think I should be able to pull 7000 pounds or so but wanted to check with everybody before I hook it up.
Thanks,
bulachip is offline   Reply With Quote
Old 04-25-2008, 04:54 PM   #2
brad4eva's Avatar
brad4eva will become famous soon enoughbrad4eva will become famous soon enough
wouldnt recommend that much for that kind of truck
brad4eva is offline   Reply With Quote
Old 04-25-2008, 05:09 PM   #3
you need to consider more things such as gear ratios, suspention rating, check the gvwr, type of hitch, etc good luck
Old 04-25-2008, 05:13 PM   #4
keithr0005005's Avatar
7 thousand is a bit much for a half ton...i mean sure the engine can handle it ive pulled 6300 with mine goin to the scrap yard but she squats real bad....its your call...oh ya and stopping is not very easy lol
Old 04-25-2008, 05:48 PM   #5
brad4eva's Avatar
yeah man you need a ton truck for that kinda **** for SAFETY
Old 04-25-2008, 07:41 PM   #6
i just towed a heavy beast of a skid steer loader to the gas station today, still trying to find it's weight info.
by time i had everything hooked up, i had 2'' between the bump stop and spring. when i tried to stop, the tongue weight finished up that gap and was pushing my truck due to the drum brakes in the rear.
unless you have trailer brakes, i wouldn't tow over 5k pounds.
found the weight info: the machine weighs 6k pounds! and thats not including the trailer.
Old 04-25-2008, 07:58 PM   #7
brad4eva's Avatar
100 % agreed with Mudseeker. You want all the safety you can get
Old 04-29-2008, 05:24 PM   #8
pulled it and it was a bit much... just went a little way. Anyway to tell if my motor is a 350 or 305?
Old 04-29-2008, 06:42 PM   #9
brad4eva's Avatar
more then likely is a 350 305 would havea tuff time pullin
Old 04-29-2008, 08:10 PM   #10
check the label under the hood if everything is original it shoul say
