| Full Member Join Date: Apr 2008 Location: sherwood forrest
| Differential gear ratios Hey fellow truckaholics,I just purchased a 65 fleetside 3/4 ton in really nice shape, was a Cailf truck. Only does 55mph wide open, has a 4 on the floor.What rearend gear ratio would be the best for 65mph?Can there be a gear swap or does the whole diff have to be changed? It has those realllllllly long swing arms. Maybe torch the unit out and put a leaf spring setup under it? Any help or advice sure would be welcome,thanks |
| yeah you can swap the gears only. the rear gear really depends on what the final gear is in the tranny too. If it is 1:1 then a 3.73 gear would be a good gear for the rearend. Won't lose anything on takeoff and still decent for cruising.
| Front Differential Leak | Charlieb | GMC Truck Forum | 5 | 04-09-2008 11:45 AM |
| S-10 souping, gear ratios, exhaust? | buumachine | Chevy Truck Forum | 2 | 12-12-2007 11:27 PM |
| -Changing Gear Ratios- | BryanCregger | Chevy Truck Forum | 16 | 03-28-2007 11:32 AM |
| Axle Ratios | SuperBen | General Truck Forum | 21 | 03-26-2007 05:54 PM |
| Differential ratio | riverasierra | GMC Truck Forum | 2 | 02-19-2007 04:58 PM |
