| Pwr door locks out - 99 Silverado The power door locks on my 99 Silverado have gone out. They will work occasionally, but... mostly not. I have no idea what causes them to change. The fuse is good and I have removed and reset the thing I believe to be a relay (located under the hood)...I even tried reversing the thing...to no effect. Any ideas? Where can one buy a new relay...if, in fact, that's what the thing is. I sure would appreciate some help. Thanks....Tom |
| Welcome to the forum Tom. You didn't mention which level of locks you have, base or up w/ remote. Base uses two relays, up level uses three relays, both use the Body Control Mod. Each of your lock motors has a circuit breaker attached. You also didn't say if the problem is just one door switch or both. Or if only Lock or unlock works / fails. First suggestion would be to check connectors are tight and grounds are good. You should be able to feel the relays engage with your fingertips. For both types, using either "Lock" switch should trip the "DoorLock" relay. The "UnLock" switch will not and uses BCM to trip different relay. Both (or all 3) relays are located in the "Left Bussed Electrical Center" Any parts store should carry replacement relays, if they are needed. |
| | #3 | |
| door locks ? | teemsta | Chevy Truck Forum | 11 | 08-02-2007 06:54 AM |
| Power Door Locks | WOT | GMC Truck Forum | 2 | 07-27-2007 06:00 AM |
| Back door locks on 04 Avalache | rlnye | Chevy Truck Forum | 0 | 06-15-2007 04:26 PM |
| 93 silverado 1500 power door locks | che | Chevy Truck Forum | 3 | 11-20-2005 11:52 PM |
| Auto Door Locks?? | mrjohnwayne | Dodge Truck Forum | 3 | 04-30-2005 05:28 PM |
