| Need to replace upper & lower ball joints I have a 1994 Chevy Fullsize Blazer with a diesel 6.5 turbo engine. I need to replace the upper & lower ball joints on both sides. Any tips on how to make this job any less painful. |
| Removing Ball Joint Tapers from the Steering Knuckle The ball joint is connected to the steering knuckle with a tapered connection, called a steering taper, which is also used in other steering connections. ![]() A ball joint taper. Courtesy of Moog Automotive, Inc. To remove a ball joint requires the use of a ball joint remover. Another way of "breaking" the taper is to use a large hammer.
![]() Three common ball joint retaining methods. Courtesy of Moog Automotive, Inc. Some ball joints are held in with rivets from the factory. The rivets are drilled and punched to remove them. Bolts and nuts are used to hold the replacement joint in place. ![]() Original equipment rivets are replaced with nuts and bolts. Courtesy of Moog Automotive, Inc. The most common method is press fit. Some manufacturers require you to replace the entire control arm assembly if a ball joint is to be replaced. In these cases, the ball joint and control arm are made as a single assembly and individual parts are not available. If the control arm has been removed from the vehicle, a pressed-fit ball joint can be removed using a standard hydraulic press. When the control arm is still on the car, a special press set allows the removal and replacement of these ball joints. Some pressed-fit ball joints have a spot weld that holds them in place. This must be carefully removed. When a replacement ball joint is installed, a snap ring often takes the place of the weld. NOTE Be sure the grease release hole in the new ball joint's rubber boot is aimed away from the brakes.
| Rent a ball joint press from the parts store!!!! It will be worth it!
| if you dont have a press, get a BFH (big hammer). its more fun that way
| question about ball joints on 98 explorer | 72'CaminoKid | Ford Truck Forum | 3 | 12-13-2007 04:46 PM |
| Upper Control Bushings | rednekracer | Chevy Truck Forum | 5 | 06-10-2007 10:25 AM |
| Lower Ball Joint | rednekracer | Chevy Truck Forum | 7 | 05-07-2007 09:03 PM |
| Lower ball joint???? | LandSharkGT | Nissan Truck Forum | 10 | 12-26-2006 03:58 PM |
| f350 ball joints | bristlehead | Ford Truck Forum | 3 | 09-17-2006 12:13 PM |
