| Junior Member Join Date: May 2008 Location: Tacoma,Wa
| 87 chevy burb cranks over but won't fire up need help please... I have a 87 chevy suburban 5.7 350 motor, today ran it dry by accident previous owner said 40 gallon found to be like 25 gallonish also gas gauge lied |
| Senior Member Join Date: Mar 2008 Location: North Carolina
| try checking coil pickup with ohmmeter.un plug from module one lead on each wire 500 to1500 ohms ok also sone times the wires brake so give them a little shake . hope this helps |
| Full Member Join Date: Apr 2008 Location: Angier, NC
| Check for spark at the coil wire to cap. The only thing that makes NO FUEL NO FIRE is the oil pressure switch, It will shut off both at the same time. Make sure it in not unplugged or broken. Some are under the distributor at the back of the intake and some are above the oil filter, and some are in both places. |
| I'll try it and i'll keep you posted. Thank you very much Troy |
| if you ran it dry maybe the comp has to be reset. take the negitive batery post off and leave it off for a min. then try to crank it. it has gotten me home before. so its worth a try |
| Have you checked for 12 volts going into the coil?
| 87 chevy burban update info.... Hello to all and thanks for the help. I put in new distributor well reman one, anyways it had new p/u coil and ignition module. Still no fire, no fuel through injectors,12v to coil fuel to tbi intake. Tried replace the module with new one no go, old one no go , old coil no go. Tried for help from the ecm it says no problems of course! P/u coil was toast on old dist. Chilton manual sucks for wiring diagrahm any suggestions? |
| did you ever look into your oil pressure switch like sneakysportsman recomended?
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 5.7 Liter/THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| Chevy, remember your problem with no voltage to the Injectors? You may have a bad circuit somewhere, wether it could be the following Ignition switch, bad fuse terminals. Power to the coil and injectors goes to the Key switch first then to the fuse panel. |
| 98 chevy 3500 dually 454 no fire ? | minnesota jim | Chevy Truck Forum | 4 | 01-24-2008 11:28 AM |
| 89 burb tbi | Lomax Anderson | Chevy Truck Forum | 1 | 01-13-2008 06:47 PM |
| 96 S10 4.3 cut out wen i was driving. cranks up but wont turn over!!! any help? | SizedoesmatR44 | Chevy Truck Forum | 6 | 06-11-2007 07:38 PM |
| For Sale 87 Burb 4X4 in TEXAS 2 owner. | gmctrucks | Truck Classifieds | 2 | 11-30-2006 10:05 AM |
| 93 Chevy 454 no fire or fuel | Jonc | Chevy Truck Forum | 7 | 10-11-2006 09:55 AM |
