Old 05-08-2008, 05:49 PM   #1
Charcarius is on a distinguished road
At a loss
Ok guys I have an 2002 1500 silverado with the 5.3 in it. I got about 135000 miles on it. I am not a mechanic by any means, merely a carpenter. My check engine light came on, got the code checked it read ramdom cylinder misfire/malfunction. I changed the spark plugs. Its still doing the same thing. I can tell it is losing power, and I have what sounds like a high pressure spray when I hit the gas any more than an old grandma in a lincoln. Can it be the coil packs or the injectors or... what I desperately need some guidance. I can;t really afford to take it to the shop and the book doesn;t have this in the troubleshoot that I can find.
Charcarius is offline   Reply With Quote
Old 05-09-2008, 12:30 AM   #2
junior3382's Avatar
Having a multi cylinder misfire can have several causes. Spark plugs being warn, plug wires having a dead spot, coils grounded out, rotor inside dist is off time by a slight. That in the ignition system. Problem could also be with injectors or mass airflow... is the only warning light a po300 code? it is not signaling running lean or too rich is it?
Being that is has 135k on it, and it is losing power, I would guess it needs a full tune up. Manufacterer recomends complete replacement of plugs and wires every 60k and coils and dist every 120k.... I would start there. being a carpenter and not a mechanic, wires may be easy, but I would also recomend bringing it to a shop for the dist. Timming has to be perfect, and they have the proper knowledge and tools. Good luck bud, I hope this helps.
Old 05-09-2008, 03:31 AM   #3
Thanks man, helps a lot. The plugs and wires were pretty easy. I was going to go with the coil packs next I guess, but I think I will take your advice on that thanks again.
Old 05-09-2008, 04:37 AM   #4
Sneakysportsman's Avatar
Sneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to beholdSneakysportsman is a splendid one to behold
Having a high pressure spray sound means you have a vaccum leak some where. Also having a code that says random cyl misfire means that it isn't only one continious cyl not firing but it is throught the engine. You have a lean engine miss. Caused from a vaccum leak.
Sneakysportsman is offline   Reply With Quote
Old 05-09-2008, 03:54 PM   #5
I take it that would also explain the whistling sound I get occasionally when the engine is cold in the morning and I am pulling out. I thought it was a belt at first but I know enough to know that it isn;t a belt.
How would I check for a vacuum leak?
Also since it has so many miles on it how hard is it to change all 8 of thouse coil packs. It looks easy but i know how things like that start out
Thanks for all the help guys
Old 05-09-2008, 05:45 PM   #6
Mega bucks!!!!! It isn't hard but you have a vaccum leak, Get a piece of tubing or a stethascope an dhold to your ear and move all around the engine and this process will pinpoint a vaccum leak.
loss of power on shift o3shortbed Chevy Truck Forum 2 01-24-2008 07:25 AM
96 GMC Suburban loss of power. Steven6456 GMC Truck Forum 3 01-15-2006 08:06 AM
El Paso starts off road trip with loss (El Paso Times) trucknews Truck News (headlines) 0 07-19-2004 02:30 PM
