[[HOME]] Free Registration to our Truck Forum Truck Pictures FAQ Members List Search Today's Posts Mark Forums Read
Old 05-11-2008, 03:52 PM   #1
pahokeejoe is on a distinguished road
85 silverado/starting problems
Hey guys, new to this forum and in desperate need of help. My 305 silverado will start at times and runs perfect. Other times she will not start. When she won't start there is no spark to the plugs. Now here is what I have done. ( rebuilt the dist. completely, replaced the dist. components three times, swapped computer, check ign batt to dist and computer when she won't start and every time the voltage is good even while cranking, replaced timing gear and chain) At times I will go to start to no avail. Sometimes try a couple of hours later and she'll start and run great. Go out the next morning and she won't start. Sometimes it will be days too weeks before she'll start again. I also have checked all wires involved with the computer,dist and ign and all test good. Outside temp seems to have some effect as too when it quits starting, but she'll do the same in the summer months as well. Any suggestions? Joe
pahokeejoe is offline   Reply With Quote
Old 05-11-2008, 10:10 PM   #2
88fivespd is on a distinguished road
I would guess the ignition coil or the ignition module. I would buy the cheapest new coil I could find and try that first.
88fivespd is offline   Reply With Quote
Old 05-12-2008, 03:45 AM   #3
I,ve replaced the coil and mod three times. Fuel pump is new and good,no problem there. When she starts, I can get on down the road, kick in the four barrel and scoot. Funny thing is, it never stalls while driving.
Old 05-12-2008, 06:13 AM   #4
Chevy_Finatic79's Avatar
Chevy_Finatic79 is just really niceChevy_Finatic79 is just really niceChevy_Finatic79 is just really niceChevy_Finatic79 is just really niceChevy_Finatic79 is just really nice
maybe you have a loose wire going to the pick up coil. i bought a new dizzy before and one of the wires going to the pick up coil was never soldered from the get go but mine just flat out wouldnt start
85' Chevy C-10 Longbox (Rat)
TBI 5.7 Liter/THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 05-13-2008, 04:48 AM   #5
Case 7230 is on a distinguished road
Check for loose/dirty/broken ground wires between body and engine. Check also for defective ign. switch and defective/loose/dirty ign switch plug connector. You may be getting voltage at coil but not enough current. Just my guess.
Old 05-14-2008, 03:55 AM   #6
thanks for info: I changed out the ign switch because it's the only thing I haven't changed. Seems to be better. I'm going to redo the grounds from body to engine and see if that helps. If she'll crank and run everyday for a couple of weeks, I might put a little faith in her and take a long drive.
Starting problems BSHeiz GMC Truck Forum 9 12-22-2007 02:16 PM
starting problems tjh1075 Dodge Truck Forum 0 02-21-2007 02:33 PM
2001 Chevy Silverado Z-71 Starting Problem a5150joseph Chevy Truck Forum 1 12-03-2006 07:11 PM
Starting problems (New Bee) Chipper GMC Truck Forum 1 11-12-2006 08:18 PM
93 silverado starting issues WetPaint Chevy Truck Forum 6 04-05-2006 05:49 AM
SEO by vBSEO 3.1.0 ©2007, Crawlability, Inc.
Copyright 2007 - Truck Forum
