| Full Member Join Date: May 2008 Location: TEXAS
| 1996 K1500 plug fouling 5.7L 4l60e auto just replaced head gaskets My #5 cylinder keeps fouling (fuel). I'll put a known good plug in and it will run great for about 5-10 minutes, then you start hearing the miss, engine starts shaking and if it's in gear, it will want to die. The plug wires are good and I am going to replace the cap and rotor, but I have been told that the fuel pressure reg. under the upper intake is prone to leaking. Is this true and how can I tell if this is the problem? JR |
| try a fuel pressure gauge attach it to schrader valve start engine idle a few seconds turn engine off if you have a leak pressure should drop pretty quickly hope this helps |
| when you pulled the intake you could have damaged the injector for the number five cyllinder. this would cause fuel to pour into the cyllinder and fould the plug |
| Thanks guys. I'll try this tomorrow. JR |
| | #5 | |
JR | |
| Guys, it was the fuel pressure regulator. It sits just above the #5 intake port and when I removed it, the filter screen was totally clogged and I'm figuring this is what caused it to leak. JR |
| Sorry I took so long to get on line again two jobs but glad you found the problem |
| 1992 5.7 TBI #1 Spark plug fouling | cplnorton | Chevy Truck Forum | 7 | 11-09-2007 08:37 PM |
| 98 tahoe fouling #3 and #5 plugs | chandler | Chevy Truck Forum | 4 | 03-17-2007 10:08 PM |
| 1996 K1500 engine swap? | Charles1221 | Chevy Truck Forum | 1 | 10-02-2006 03:27 AM |
| spark plug | project88 | General Truck Forum | 8 | 05-08-2006 10:09 AM |
| One fouled spark plug on 95 K1500 | tackepj | Chevy Truck Forum | 9 | 05-05-2006 12:17 PM |
