Old 05-14-2008, 12:28 PM   #1
thamick7 is on a distinguished road
Dies when driving - help please!!
When driving down the road, (2000 silv. 5.3) shuts down and then idles roughly at about 200 rpm and within a few seconds dies. Pushing the gas doesnt change it any. It will always restart after about 30 seconds. Please any help would be greatly appreciated.
Brandon
thamick7 is offline   Reply With Quote
Old 05-14-2008, 03:15 PM   #2
Moderator
is it showing any codes??
Old 05-14-2008, 06:15 PM   #3
Moostang's Avatar
You say "shuts down then idles roughly" can you explain that better, does it completely shut off, or just act like you let off the gas.
I am wondering if it is the fuel pump or a fuel relay..
MEOW!!
Old 05-14-2008, 07:04 PM   #4
fuel filter, pressure regulator, ping pong ball in the tank! good scan tools are worth their weight in gold
Old 05-15-2008, 09:20 AM   #5
It is not showing any codes. When driving down the road, the engine shuts down like turning off the key. If i pull right over and put it in neutral, it chugs for a few seconds and then shuts off completely. If it does it when i am at a light, it starts to slowly lose fuel (rough idle) and then goes into the same as above. It is completely random, however when the temp gets to 80, it does it more often on my drive home. up to 5 times so far on a 20 min drive
thanks for all of your help
Brandon
Old 05-15-2008, 10:04 AM   #6
Moostang's Avatar
Is it only after the car is warm? If it was a ford I may have to say the fuel relay switch it getting hot
MEOW!!
Old 05-15-2008, 11:05 AM   #7
yeah, only after it gets warm. But it doesnt have to be full operating temp. Another thing that makes this hard to diagnose, is, it only happens on the way home from work about 5pm. it has never died on the way, 8am
Old 05-15-2008, 11:14 AM   #8
Moostang's Avatar
Its probably hotter out then, do you know if you have a fuel relay switch? Do you have a hanes manual you can look at?
MEOW!!
Old 05-15-2008, 01:05 PM   #9
yeah it has one
Old 05-17-2008, 08:40 PM   #10
gaander is on a distinguished road
Did you replace the fuel relay switch? If so, did it fix the problem? I ask because I have an '88 GMC Sierra 1500 and have been having the same problems. They just put a new ECM in and is still doing the same. Mine does it when it's hot or cold. It doesn't seem to matter much. Thanks.
Greg
gaander is offline   Reply With Quote
Who's driving what and why (poll) LedBetter General Truck Forum 30 10-26-2007 01:04 PM
rattle noise when driving fordbigman Ford Truck Forum 7 09-15-2006 06:34 PM
96 K1500 Just shutting off while driving! Charles1221 Chevy Truck Forum 2 08-02-2006 09:17 PM
bad shaking when driving 98Z71 Chevy Truck Forum 10 10-26-2005 09:20 PM
Driving cold Moostang General Truck Forum 8 10-13-2005 06:43 PM
