| 1987 tbi ignition Can anyone tell me were i can find the plug to disconnect to set the base timing on a 1987 tbi chevy truck. Also what do i have to do to get fuel tank out? Its on the driver side and when i unbolt the straps it only drops down a few inches and the rubber lines hold it up? Do i cut the lines and replace with longer high pressure ones? Thanks!!!! kkustomz1@aol.com |
| you should take another look at your fuel lines and follow them until the rubber turns into metal thats either gonna be toward the tank or the frame rail depending on what GM did. then there should be a line fitting that looks like nut(s) that's where you dissconnect them. on my trucks the base timing wire is tan with a black chaser and is in different locations on each truck. the connector you are looking for is identical to the O2 sensor wire connector. heres a couple pics: ![]() ![]()
__________________ "She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 327 Cu.In./THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
| 1987 Chevy 2x4 into a 4x4?? | frese9 | Chevy Truck Forum | 5 | 02-18-2008 04:20 PM |
| 1987 Chevy S/w/b | FIRE6 | Truck Classifieds | 1 | 01-09-2008 06:52 AM |
| 5.3 in 1987 chevy | ace | Chevy Truck Forum | 3 | 10-26-2007 08:39 AM |
| Location of ESC connector 1987 V10 | wojeepster | Chevy Truck Forum | 3 | 10-11-2007 12:35 PM |
| 1987 S10 problem...help?? | jutland | Chevy Truck Forum | 1 | 11-20-2006 05:40 PM |
