Old 05-21-2008, 07:39 PM   #1 (permalink)
X2CRAYZIX's Avatar
X2CRAYZIX is on a distinguished road
Please someone , im at the end of my rope with this one
My truck starts good and will run good till it heats up to about 210 degrees on the heat guage and then it will start to studder and backfire. Ive changed the coil , plugs, wires, ignition control module , cap and rotor and its still doing it . Anyone know what this might be . My truck is a 95 GMC k1500.
X2CRAYZIX is offline   Reply With Quote
Old 05-21-2008, 08:50 PM   #2 (permalink)
Moderator
mudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to behold
my best guess would be a faulty coolant temp sensor.
(copy/past)
COOLANT SENSOR. Usually located on the cylinder head or intake manifold, the coolant sensor is used to monitor the temperature of the engine coolant. Its resistance changes in proportion to coolant temperature. Input from the coolant sensor tells the computer when the engine is warm so the PCM can go into closed loop feedback fuel control and handle other emission functions (EGR, canister purge, etc.) that may be temperature dependent.
Coolant Sensor Strategies: The coolant sensor is a pretty reliable sensor, but if it fails it can prevent the engine control system from going into closed loop. This will result in a rich fuel mixture, excessive fuel consumption and elevated carbon monoxide (CO) emissions - which may cause the vehicle to fail an emissions test.
A bad sensor can be diagnosed by measuring its resistance and watching for a change as the engine warms up. No change, or an open or closed reading would indicate a bad sensor.
proud member of the 200k mile club
boys never stop playing with toys
Old 05-22-2008, 03:30 AM   #3 (permalink)
PAPA BEAR's Avatar
PAPA BEAR has a spectacular aura aboutPAPA BEAR has a spectacular aura about
try testing coil pick up after it starts running rough. good luck
PAPA BEAR is online now   Reply With Quote
Old 05-22-2008, 05:44 AM   #4 (permalink)
Chevy_Finatic79's Avatar
Chevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to all
what about your O2 sensor have you changed that? sounds like when it heats up and runs off the O2 info it stutters and spits. just a thought
85' Chevy C-10 Longbox (Rat)
TBI 5.7 Liter/THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Old 05-22-2008, 09:19 AM   #5 (permalink)
X2CRAYZIX's Avatar
Could a bad MAP sensor cause this?
Old 05-22-2008, 09:40 AM   #6 (permalink)
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
veirfy good fuel pressure, then look into the coolant temp sensor
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Old 05-22-2008, 12:14 PM   #7 (permalink)
X2CRAYZIX's Avatar
do you think the coolant temp switch would cause it to lose fuel and backfire?
Old 05-22-2008, 11:32 PM   #8 (permalink)
maverick25204's Avatar
maverick25204 has a spectacular aura aboutmaverick25204 has a spectacular aura aboutmaverick25204 has a spectacular aura about
also check leaky intake after warm but coolant sensor first most likely
maverick25204 is offline   Reply With Quote
Old 05-23-2008, 04:42 AM   #9 (permalink)
Moostang's Avatar
Moostang is a splendid one to beholdMoostang is a splendid one to beholdMoostang is a splendid one to beholdMoostang is a splendid one to beholdMoostang is a splendid one to beholdMoostang is a splendid one to beholdMoostang is a splendid one to behold
merged threads, FYI, if you guys see a dup you can use the "Report a post" because sometimes we don't notice if one is on the 1st page of new post and the second is on another page.
MEOW!!
Old 05-23-2008, 04:58 AM   #10 (permalink)
X2CRAYZIX's Avatar
ty
thanks for combining the threads and sorry.
