| | #21 |
| | #22 |
| Full Member Join Date: May 2008 Location: Orlando Fl
| if you have an intake leak you will hear a difference in the rpms(they would raise). I use carburator cleaner myself but it is the same principle. Tom |
| | #23 |
| so i let it idle and then spray fluid around it and if it revs some i should suspect a leak? |
| | #24 |
| Senior Member Join Date: May 2008 Location: ok
| yes make u use that u dont mist to the carb it will give u a false rev
__________________ well sh... |
| | #25 |
| well that came out wrong make sure u dont mist the carb
| | #26 |
| cha ching it turns out that the distributor was failing and a new one is on now and all is good so far |
| | #27 |
| good to hear it seems to be fixed.
